My pleasure, any time!Thank you for the kind advice @Dean62 Dean and for helping Phil out. It is much appreciated.
Very well done! This will make placing the waterway boards much easier, and it looks better. I think you are in good shape for doing the final fairing after internal framing is completed.Here is an update.
Removed, refitted, and reinstalled frames 50-56 on both sides. Also corrected the frame alignments by using spacers. Special thanks to Dean. Although not perfect, they appear to me to be much better, and hopefully ready to proceed forward. I welcome any comments and send best regards to all fellow modelers.
PhilView attachment 254516View attachment 254517View attachment 254518View attachment 254519
Step by step you're moving towards a beautifully crafted model.Update. Started the internal framing. Had some difficulty at first but when I followed Peter Voogt's example for clamping the results were quite solid. Thank you Peter!
Progress has been slow, but sometimes life interferes with modeling. a few photos below. Next will be sanding and possibly a clear coat, then move forward from there with the lower decking. I stand on the shoulders of giants. Comments, or corrections are always welcome. Thanks to all of you for your help. Best regards. View attachment 258499View attachment 258499View attachment 258500View attachment 258501View attachment 258502View attachment 258503View attachment 258504.
Here are a few pictures.
Hi Phil. You made a good progress with the inner framing.Update. Started the internal framing. Had some difficulty at first but when I followed Peter Voogt's example for clamping the results were quite solid. Thank you Peter!
I don’t see the bevel-laser-lines anymore, so it will be allright, Phil.Thank you Peter. I did bevel the upside of the frame bearing beam, I believe part 135 if that is what you are referring to?
I am removing carbon from the lower deck beams, parts 75-101. I tried fitting a couple and they seem to lie flat with enough of a purchase on the bearing beams for security. I hope I am getting your drift.
Best wishes, Phil
