First Question! Why doesn't this boat have any oars? It is towed by another boat?
Why do you say it doesn't have oars?First Question! Why doesn't this boat have any oars? It is towed by another boat?
Nevermind... I read your first paragraph wrong.Why do you say it doesn't have oars?
All the very best to you on this project -I decided to build my esping based on a solid hull template. I will then plank that solid hull template and later remove the hull in order to add frames and other details afterwards (hull first rather than frame first).
A chunk of basswood in hand I have now used rubber cement to paste my plans to the block of wood:
I then used the drawings to create shape templates that correspond to various locations along the hull of the ship (it is here I hope I have understood the drawings and how to best use the loft lines). These templates will guide the shaping of the solid hull form...
Wish me luck!
In dental school you have to carve each of these teeth out of chalk in order to learn proper anatomy... I had two classmates drop out because they couldn't do it!Wow Paul your first scratch build, that will be fun.
About reading drawings I don t worry.
Guess you can read this drawing
so the plan of a boot won t be a problem.
Oh no he can carve also. I think I will quit this hobby.In dental school you have to carve each of these teeth out of chalk in order to learn proper anatomy... I had two classmates drop out because they couldn't do it!
Excellent tip thank you.I can't wait to see him spile that hull. He's gonna hurt himself. . .
Oh well.. guess I better help him...
HEY PAUL! Here's a method to help you make patterns for spiled planks on that deeply curved hull. Use the TAPE PULL METHOD, Cover the hull with tape, DRAW the plank lined on the tape, Number the planks and PHOTOGRAPH THEM ON THE HULL, carefully pull the tape off, and cut along the lines. Lay the tape flat on thin wood, and cut the wood at the edges of the tape pattern. Use your photos and plank numbers to show you where they go. It saves lots of guesswork.
Hi Ken,Paul, I really like your unique approach. Innovation plants the seeds for others that otherwise might not exist. Did you treat the hull (sanding sealer).?? I've worked with basswood a lot and your one photo shows a very "satin' looking finish that I've not ever seen in my work with basswood. Also, do you plan to carve a void in the solid hull? I ask only because I am fascinated with this unfamiliar approach.
While I've built models, I've never shared my project's build steps, until recently. This has obviously revealed an opportunity for me to learn more about photography and image management/sharing, which you are obviously very proficient at. I notice your dark blue back drop.
I am going to try and develop my own skills to present and share images. If nothing else, to prevent SoS members viewing my work to have migraine headaches.
Great looking work. Looking forward to your next post
Indeed that was the original plan. That's why there is a flat board in an early photo. I was going to add the frames to the hull form (sticking their overly long ends into holes in that flat board at each of the frame stations) and then plank over the frames precisely as you mentioned. But the fact that there is not a continuous keel caused me to rethink the viability of that approach (a full keel would provide stabilization of the frames along the midline). I am confident I could come up with a workaround and if my current effort crashes and burns I'll try again using the approach you have suggested (necessarily making the hull form smaller to account for the thickness of the frames).Great to see another project from you Paul
My personal preference is frame over form then plank but either way works.The one thing I would say though is spilling is the only way to go, you do not want to build in any stresses with small boats like this otherwise you run the risk of the hull twisting out of shape when removed from the form.
Kind Regards
Nigel
Clever. I'll give that a try!I can't wait to see him spile that hull. He's gonna hurt himself. . .
