- Dec 1, 2016
PLANKING 3A
Last time, I stuck the partition wall on the front side, glued the keel, and put the side reference
line with a pencil to finish.
This time I stuck the outer skin of the hips. After this, the outer plate was cut neatly to match
the outline of the stern.
This is a picture taken from behind diagonally before cutting it neatly.
The outer plate is pasted from the red arrow part.
Stick 2 mm thick and 4 mm wide cypress into the red arrow and stick it up with that as a reference.
I use 4mm width, 3mm width, and 2mm width cypress according to the place.
But the main width is 3mm.
Enlarged photo of the stern part.
The part of the groove is 2mm wide and 1mm thick cypress. If you stick a 2mm thick material on this,
it will pop out by 1mm.
Two pieces of 4mm width are stuck on it.
Enlarged photo of the side of the ship.
Enlarged photo of the bow.
After this, I will paste it on top.
I could stick the outer plate of the bow part, port and starboard somehow. I have to move it
to the left and right at the same time.
I will stick the outer plate of the stern part, the port and starboard.
I also pasted the stern part to the top!
After that it is pasting from the waterline to the bottom part.
I stuck it on the bottom of the water line and managed to get to this point.
I have a little more.
Is it about 2 pieces of 3mm wide cypress?
I've finally pasted it.
There were days when I couldn't paste it, so I was a little dissatisfied.
When pasted up, the outer plate is rattling.
Is there any trick to put it neatly?
Even if you stick it carefully, there will be gaps and there will be steps, so it will be a problem.
After this, sandpaper is applied.
Also, the edge of the protruding material is cut cleanly.
I scraped it with an electric sander for about 2 hours.
The hull was somehow clean, so I cut off the edge of the outer skin.
Then, the pillars of the frame were cut off and sandpaper was applied to the inner wall.
I attached the stem part of the bow with epoxy adhesive and tightened it firmly with screws.
I temporarily assembled a beak head on the stem of the bow.
The stem is grooved so I just inserted the beakhead.
Have you seen the whole picture?
This is a close-up photo of Beekhead.
