- Dec 1, 2016
part 20
Deck material was struck on the upper terrace. It is a 3 mm wide 0.5 mm thick cypress.
I put the outer plate material on the mask on the upper terrace. It is a 1 mm thick cypress
with a width of 5 mm.
I am putting a decorative board on the side of the terrace above.
Next, on the terrace below, we also applied deck boards, outer boards, and side panels.
Handrail support
I will shave from 2×2×91 mm cypress lumber.
Scrape the lower part of the pillar……
Next, trim the upper part of the pillar to shape it
Completed by separating... Repeat this [sweat]
When about 6 pillars were made, the pillars were positioned on the terrace side.
It's an expansion of 6 struts. Since we will build it from the terrace above, we need about 9 more.
Handrail construction on the upper terrace
When the pillar is made, load the brass wire...
Set up the pillars on the terrace.
I have set up all the columns.
Underlaying of the handrail. It is working with the actual product using a 0.6 mm aviation veneer.
So there is no drawing.
After finishing the underlaying of the handrail, attach a decorative plate (cypress cypress 0.5mm thick)
on it. First of all, from the center railing...
When the middle is finished, paste both sides.
It is completed after finishing the veneer. I want to see the horns at the four corners,
but I will make it after the lower terrace part is made. It's a little distorted, but I don't care (laughs)
A view from the side.
This is the view from below.
That's all for this time.
I stopped working from FD1-72-19 .
It is finally time to resume work.
Next is a large terrace with a terrace.
I wonder how many posts have to be cut out?
I interrupted my work and worked a lot. Photo shooting, video shooting, package design, etc.
Finally, after finishing my work, I will resume production of the FD issue.
Handrail support
