- Dec 1, 2016
Captain room bulkhead work part 33
I made a quick drawing.
I made a jig for making a frame for doors using a plywood 5.5 mm thick.
Soak cypress 1mm thick x 2mm wide in hot water. It takes about 20 minutes.
Put 2 pieces of 1mm thick cypress into the jig and put them in the mold. Leave it to dry.
When it is dry, take it out, take out the two pieces, bond them with a tight bond, and put
them in the jig formwork again.
When the adhesive dries, take it out and the door frame is completed. Make two of these.
It is a work of the partition wall of the captain's room. It's small at 1/72, so it's difficult to make……
Still, it has managed to take shape.
In addition, decorate.
I made a door. The large hinge metal fittings use a 0.3 mm thick plastic plate and reproduce
the bolt with a 0.5 mm brass wire. The knob used the head of the insect pin.
I painted it.
It's the usual German gray thinner shabu-shabu. The metal fittings painted the ground.
I tried to temporarily assemble it on the hull.
It looks like this. Without bulwarks, stairs, etc.
I painted it.
