- Dec 1, 2016
When I was watching a DVD to draw a drawing of a rat (held wheel), PART 41
I found that there were various mistakes and strange things...
Well, that's what movies are like.
Now, in my mistake, it's the gangway rope handling. I used to tie it directly
to the pole of the handrail on the bow side, but in reality, the pole had a
ring pin and I was tying it to the ring.
The gangway rope, on the stern side, was also tied to the pole of the handrail, but actually
the rope ended with the pole for the gangway rope railing.
The red arrow in the red frame is the last support for the rope railing.
It's a funny part of the movie. …The round hole in the red frame, this is where the cannon is
actually located, but I don't have the cannon, as it might prevent Jones from coming down the stairs.
However, the red arrow on the right and the brown barrel are slightly visible. In the second video
from above, Jack Sparrow has a tack on the main lower sail, breaks the pin rail and blows it up
to the lower yard, but is there a cannon cannon? ......
It is the story of the corrected part.
The red arrow part of the red circle frame, the fife rail part that is an obstacle when using the stairs ...
I cut it.
Gangway's rope handrail, this is the stern side, but the bow side is also tied to the handrail post,
but it is wrong.
On the bow side, there is a ring pin on the column, and the correct answer is to tie it to the ring.
On the stern side, there is a support for the rope handrail, and it seems correct that it is
tied to the ring pin of that support.
Pay attention to the red arrow!
It looks like this.
It is an image of the stern side after fixing the rope handrail.
Similarly, the image of the bow side with the rope handrail fixed.
I installed a cannon on a deck with a capstan on the stern side. The image seen from above.
Image on the port side.
Drawing of rat (held wheel)
This drawing is the steering wheel drawing of the Black Pearl.
It's a drawing that I can see, so stop pushing.
I didn't know the pedestal part of the Flying Dutchman's helm even if I
watched the DVD many times, so I wondered if I could make it like the BP's
pedestal part, but in the end I decided to go with a different shape.
That is the drawing below.
Here is a drawing of the helm and pedestal.
Since it is impossible to make a work as shown in the drawing, I will make it
by saying that it is OK if it resembles.
Maybe it looks like deformation.
It is a part of the rat part.
Since the rudder wheels are directly attached to the front and rear of the drum part
where the rope is wound, it is assembled in that way.
Well, it's deformed at this point.
I attached front and rear steering wheels.
The handle is too big...
But it may be emphasized.
I put a 0.5mm brass wire in the center of the drum.
The rest is making a pedestal, but this is it for today.
Well, it took a lot of time to make this far. The wheel in the steering
wheel part is cut out from the wood pipe after making a hole for the handle,
but immediately after cutting out, it kicks back against the blade of a circular
saw and crushes against the wall, or sandpaper and cracks. came.
The handle also took time.
It is carved out from a toothpick.
Next, we plan to make a pedestal for rat (snake wheel) and pin rail for bulwark,
and to install a cannon on the upper deck of the bow side... Plan is undecided... It was
I cut it.
but it is wrong.
It looks like this.
