- Jan 9, 2020
Hello Everyone.
I am sure that you are getting tired of all this research and technical talk - but I promise - tonight is the second-last research posting. After this all that remains is the final conclusion and decision.
You know how one sometimes looks at something without actually comprehending what it is that you are seeing? Well that is what happened to me. For goodness knows how long, I have been comparing Hoving and De Weerdt's plans to that of Kolderstok and to my model and never picked up on a glaring difference. Until it finally struck home!
Notice the three "steps" or "levels" that my rear bulwarks follow in their build-up towards the stern.
Now look at this:
De Weerdt
Hoving
So - what is amiss here? I delved back into the books and there De Weerdt very clearly stipulated: The high build-up at the stern probably housed a cabin of sorts.” He subsequently goes on to say that in all likelihood it would have been the cabin of Willem Barentsz and/or Jacob Heemskerck.
All good, but how does the presence of the cabin influence the number of steps in the rear bulwarks? Easy - the cabin has to have a floor and a roof - the latter determined by the lower (overloop or orlop) deck and the roof by one of the upper-decks. If the model does not have the captain's cabin, its deck layout and the subsequent bulwark heights will be different from one which has to make provision for a cabin. So why then did Hans not include the cabin? For the simple reason that the cabin will virtually be invisible.
So let me show you what the cabin looks like: (By the way, Hoving and De Weerdt are 100% in agreement with regards to its location and existence.)
Cabin marked in orange on the De Weerdt plans. Note the helmsman in front of the cabin in his helmsman's hut. You can also clearly see the whipstaff-idea that De Weerdt and Kolderstok subscribe to.
Cabin marked in orange on Hoving's plan. Notice the absence of helmsman's hut due to the fact that Hoving believed the Willem Barentsz used a tiller and not a whipstaff to steer the rudder.
The following pictures show the construction of the cabin according to Hoving's plans. The model builder was Constant Willems on Modelbouwforum.
The captain’s cabin – right behind the mizzen mast.
With the build-up of the bulwarks completed at the stern, that is what it looks like.
And that is the position that the helmsman will assume behind the rear canopy - exposed to all the elements. (Wild Men of Steel)
On the completed model that is what will be visible of the captain's cabin. Also note the complete absence of any front or rear walls on the canopy.
The next two pictures show the De Weerdt configuration.
Captain's Cabin. The roof beams that are just visible in the picture are those of the rear canopy.
Final configuration of De Weerdt on the Koos Weestra model. As you will see there is almost nothing of the cabin visible, but with the open rear canopy and possible addition of LED Lighting to the model, it should create a nice display - not nearly as aesthetically pleasing as my model is with its closed front wall and doors - but correct.
So, just as I laid my thoughts on the table for you guys, just so I laid them on the table for Hans - plus a few other suggestions that I will still get to at a later stage. And within 24-hours I had an amended line drawing of the @Kolderstok plans! This is not even a case of service anymore - it is a case of friendship!
Now it's just a question of thrashing out a few details with Hans and hopefully I can make an announcement to the final configuration soon!
That is all for now - until the next instalment.
Now look at this:
De Weerdt
Hoving
Thank you very much my dear friend for those beautiful sentiments. To me, one of the interpretations now makes perfect sense and I understand every nook and cranny of its lay-out. You are in the wonderful position that it is early enough in the build to decide which way you want to go. Hoving or De Weerdt or keep it standard! My research came too late for my own good!Oh wow. To date i’ve struggled to conform and place the first plank on my WB build. Your build log and Kolderstok’s plans and instructions are my “textbook“. Your research and comparison to the known, the interpreted and assumed facts is amazing. Regardless of the historical differences you’ve noted in your incredible post, your build can be classified as an extraordinarily crafted model.
But this time there is no rush - and make no mistake - oak is a different story!
