That looks very nice, Heinrich. Looking forward when you show us both WB’s side by side.Hello Dear Friends
Building continues.
I started the day by beginning the boxing of the hull in anticipation for planking. At this point it will just be a partial boxing until the fairing of the hull has been done. The pic above shows the opening for the main mast left open.
I borrowed the main mast from WB #1 just to make sure everything is in order.
A very nice and tight fit - just as it should be.
Sawing 28mm long pieces of Paulownia wood and then gluing them to the underside of the hull was perfectly ok for a while, but hardly stimulating or challenging. Cannons sounded much more interesting!
So, what did the cannons on the WB actually look like? Well to start with, they were three-wheelers and in all likelihood 6-and 3-pounders.
When the replica's rudder was hung, the occasion was celebrated by the firing of one of the cannons.
Onboard the ship.
Now those of you who have followed my log will know that I also cut open gunports on WB #1 but somehow never got around doing something about it. When I start planking, I become so engrossed with it that the hull was closed before I did anything about the cannons. This time, I wasn't going to let that open - those gunports gave me too much trouble not to utilize them properly!
The main problem was how to fix the cannons to the carriages in a way that is absolutely permanent and 100% secure (if there is such a thing), because once the next deck is on, that's it - there is no further access. The issue was compounded by the fact that I don't have any soldering and/or flux and I can only order that on the weekend when the admiral is here to do it for me. Then it struck me - on WB #1, I used the @Kolderstok-supplied brass nails as a makeshift trunnion just for fitment purposes. Somehow, the thought of these brass nails remained stuck in my mind.
What I did was to create a wooden bed for the cannon inside the gun carriage which would mean that the barrel will be absolutely level. Moreover, it also provided the opportunity of creating a 100% uniform result - in other words, making sure that both barrels are mounted at the same height and angle. The cannon was then laid down on top of its bed and rotated so that the trunnion hole was vertical instead of lateral. And yep, you guessed, nailed down from the top into the wooden bed by the brass nail.
Cannons done. I am pretty confident that those barrels will not separate from the gun carriage for as long as the model exists. Obviously, the severe lack of space made things like gun carriage wheels, hooks, rings, tackle, trunnions and trunnion caps impossible to incorporate into the space that I have available. At the back I I even had to shorten the cannons to make sure that they would fit between the two bulkheads. The picture below, shows them dry-fitted on their special decks.
And this is what they look like from the business end (dry-fit).
With that I am really, really happy and all of a sudden, the combination of the brass cannons, the red gunport linings and the oak, looks great to me! They will be glued down permanently - each on its own mini-deck - once the hull fairing has been completed.
Regard, Peter
