- Jan 9, 2020
@RDN1954 Hello Johan. I agree with Hans - I also think it is a great question. What I really appreciate about the question is the fact that you have the courage to say and verbalize what many others may be thinking, but are too hesitant to say aloud. That is the kind of question we all need, as it offers the opportunity of explanation. On the other hand, however, it can only be explained if the kit manufacturer takes an active interest in the build of his models, is preferably a modeler himself and takes the interest of his customers' builds to heart. And that is what I appreciate so much about Hans - he actively participates, because he loves this hobby just as much as we do. If we have these two ingredients of an excellent question and an equally great answer, we are set up for another high-level discussion. Once again, I cannot tell you guys enough how much appreciate the participation on this log.
So with that said, let me give you my perspective. I know the Kolderstok kits well having studied Hans's development reports of each new kit as he built them and then wrote the accompanying reports. The Batavia was designed from the outset to be equipped with guns, hence more than adequate provisions were made and even so, you will see that on all Batavia builds the 12th gunport (the one closest to the bow) remains closed because there is a bulkhead in the way. On the Zeven Provincien with its 84 cannons there is also one area where the bulkheads need to be filed away to accommodate the cannon. On the Duyfken all cannons are mounted top-deck, so no problem there. However, on the Willem Barentsz and the Fluit, installing cannons were never intended - so I knew exactly what I was letting myself in for, deciding to build the WB - as I did with the planking of a hull with a zeeg (sway) like that.
Now let me tell you a little secret and some insight to the real pain in the a*** I can be sometimes. Just filing away the bulkheads are perfectly OK for the insertion of the fillers - you do not need to cut the bulkhead portion away. But, if I didn't remove them, there would have been a very small gap (probably no more than half a millimeter) between the filler piece and the bulkhead. To all sane people this would have been fine, because the whole area is covered by the gunport lids in any case afterwards. But because I was showing the process step-by-step, I did not want to post pictures that could possibly show little gaps - I wanted it to be "perfect" - that is why I removed those sections of the bulkheads.
I will post pictures later today, but last night I dry-fitted the cut-out lids in their places - just beautiful / perfect, if I may say so myself. In the past, I would never have bothered to cut out ports in a way that I could re-use the lids. This build has forced me to do that and in doing so, has taught me another skill. That is what gives accomplishment and build satisfaction.
I hope that my two cents make sense!
