My dear friend, Stephan.And now the old drawings 16th or 17th century from these ships.
A correct answer earns the contestant bragging rights as to having thorough knowledge of the build log. Clue: It is not the first time that I have posted a picture like this.
Butler, maid, or all the servants pull cords to their call bells.Okiedokie, back to the build.
The mizzen is done for now. The "geer" (block) still needs to be added to added on the side of the scheerstrook, but that is at a later stage during actual fitment of the mizzen mast.
Question: Does anyone want to venture a guess as to what part of the build, this picture pertains?A correct answer earns the contestant bragging rights as to having thorough knowledge of the build log. Clue: It is not the first time that I have posted a picture like this.
Good answer Daniel. Actually, it is just a little rig that I used to straighten the gunport lids' cables after it was soaked in diluted PVA.Butler, maid, or all the servants pull cords to their call bells.![]()
Thank you, Daniel. It is nice to be working on the ship again.Nice to see progress on her again Heinrich.
Thank you, Peter. It is weird to post such a small update, but studying the rigging, looking at build photos, prepping the blocks (serving/stropping), fixing them to the pins and then finally to the model, took up most of the day. Clearly, I am very rusty.Nice work ,my friend, and, you are making progress.
Very true, my friend!You're not rusty my friend, but by building the hull of the vessel, you are only halfway the entire proces of building a ship.
In other words, the rigging and sails are also very time-consuming![]()
Hi Peter. Exactly for that reason - it makes it easy to install them relatively straight and they lie flat against the hull. You can also manipulate them relatively easy by effecting just enough of a twist to make it look realistic.Hi Heinrich, your WB is looking great. Question, why do you soak the ropes for the gunport lids into diluted PVA. I know when dry they become stiff as a bone.
Thank you, Johan. Thankfully, I have very good rigging plans for this ship and for once, they are all more or less in agreement (save for a few small details). A good dose of luck, however, is always a welcome commodity.Rigging is one of the more challenging tasks of a build. It definitely requires your undivided attention and a continuous checking of plans, with high risk of misreading them.
I wish you the best of luck, but your saving grace is the fact you've done it before, so it should be a walk in the park...
Yes, luck helps. But Anna is more reliableThank you, Johan. Thankfully, I have very good rigging plans for this ship and for once, they are all more or less in agreement (save for a few small details). A good dose of luck, however, is always a welcome commodity.![]()
very true, Paul, but Anna has yet to be called in for help. The hardware is all my responsibility, so I need the luck.Yes, luck helps. But Anna is more reliable.
