Awesome! Have a great birthday Ken!
or
or
or
or
your choice
Hi Craig. Like yourself I found that identifying the parts and following the instructions a bit of a nightmare. Once I’d figured it out it made more sense, seeing it in my log it probably looked easy but it really wasn’t. You’re not alone in finding the build difficult. I’m sorry that I can’t help you with identifying the pieces as it is now a while since the build, but stick with it, make your version and good luck with it.Good evening Ken,
I am thankful that you logged this build because without it I would be more lost that I usually am. I'm trying to assemble the capstan and I've been able to find most of the pieces except parts A2-11 and A2-12. The "instructions" refer to "formwork". What is formwork? Additionally what the are the numbers for the small platforms on which the upper and lower parts of the capstan sit? Also your note about placing the lower part of captan assembly in the lower deck is helpful.
I've also looked at the components for the tiller and having trouble finding them too. Perhaps I'll get a better idea as I review further in you log.
As always I am grateful for your guidance.
Craig
Good morning Ken,Hi Craig. Like yourself I found that identifying the parts and following the instructions a bit of a nightmare. Once I’d figured it out it made more sense, seeing it in my log it probably looked easy but it really wasn’t. You’re not alone in finding the build difficult. I’m sorry that I can’t help you with identifying the pieces as it is now a while since the build, but stick with it, make your version and good luck with it.
Just remembered, that small square base, I ended up making it from scrap, the size wasn’t important.
