HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Good point - I was think about before how to solve this.
My reason, why I made here a difference is the fact, that the beams on the forecastle and also at the quarterdeck have a reduced width, but the beams of the main deck are wider.
you can see the difference maybe here
This is the main reason - when the space is not enough, the width too small, the treenails have to be in one row
Hi Ewe, Your build continues to impress me, more so now that I realise just how much effort goes into a POF model.
Many Thanks for the kind comments and all the likes received.
Going further with the works on the sheerrails - this time the poopdeck at the bow
The outer epper plank was neded and installed - the kit sheerrail top is fitting very good from the form
Visible in the drawing is the fact, that the cathead is embedded inside so is deviding the top into two parts (see the laser marks on the part)
So before going further I had to make the cathead beam
and I had to make a notch in the inner and also outer plank
The necessary bolts (copper nails) are installed - these bolts are fixing the cathead down to the available beams and the top of the frame at the sheer rail
and the view from the outside
I have to go a little bit deeper.....the cathead beam has to lay flat on the planking
Many Thanks for your interest ..... to be continued ....
Really like how you made the cathead beams, especially those tiny little notches.
Many Thanks to @Keef , @dockattner , @sevish , @GrantTyler , @Tobias , @Maarten , @Ken , @Peter Voogt , @Dean62 , @Sameo_Patrik and @Alan56 for your replies and kind words
and to all others which marked the post with a like
Much appreciated and motivating.....
I needed a break from the works on the upper deck (and upper part) of the model, so I decided to start with the planking of the lower hull segment.
But before I was able to start with the first planking row directly under the wales, I had to adjust slightly the laying and hanging knees etc. close to the stern of the model. There was before a gap and the two parts of the model did not fit completely together.
The first row of planking under the wales should be as close as possible following the wales - although the upper part of the model will be appr. 15 cm higher than the lower hull
Now the hull is prepared for the first planking row of the lower hull segment
Many Thanks for your interest .... to be continued
My dear friend Uwek
first of all I want to bless you and your family a merry Christmas and Happy new year :)
you are doing wonderful and accurate on your beautiful model
Many Thanks @Mirek , @Hoss6262 , @Tobias , @Peter Gutterman , @pianoforte , @Steef66 and @shota70 for the kind words and comments.
and also to everybody pushing the LIKE-button - It is so easy here to make me smiling - Thanks a lot
The start was made and the first row of the hull planing of the lower hull segment was done - afterwards I hope it will go easier and faster
It is looking wrong, but the wales of the upper part are "hanging over" in some areas
I have the feeling, that I assembled 1.000 times the upper part on top of the lower part, in order to get more or less the correct alignment of this first plank
The second row is prepared and bended
This time I try also to imitate a fine line of "caulking" between the planks - we will see the result only after the final sanding of the hull surface - but I try and will see later on, how it is looking
You can never have enough of different clamps
I hope, that during the christmas Holidays I will have some time to work on the planking (and treenailing)
MERRY CHRISTMAS to all of you
Keep care and stay healthy
