HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Hallo,
I am using this waterbased wood glue Ponal Express because of several reasons
1) good quality glue and available here (Austria and Germany) in every hardwareshop - one bottle with (I think 400 or 500 ml) for appr. 5 Euros - enough for one year of intensive glueing
2) strong bound / strength after some minutes
3) hardened more or less invisible
4) with some water you can every time re-open the glue-point
Only on some special tasks I use the superglue special for wood produced by Tidebond - the smaller bottles in the photo
the wood glue from Tidebond I tried, but I am not absolutely happy with the results
for plastic and metal parts I am using some times these glues Woldoclean (tipp by another member here)
Many Thanks to all of your kind comments and all the likes received
I started with the oven which is included in the kit - included are one very good photoetch-sheet and also some plastic wall elements
The upper part of the chimney I made already, because this will be installed at the upper part of the model
I first dryfit of the wall elements
I started with some colouring of the wall elements - never did such weathering before - so I am not sure, what will be the outcome
It is starting to look a little bit like bricks
Many Thanks for your interest .... to be continued ....
Bonjour, quelle technique avez vous employé pour vieillir le four ?
Hello, what technique did you use to age the oven?
{Deleted} Sorry, after more research, I found your (Ewe's) clear answer. I didn't see a way to delete the post entirely.
Witaj
Piec wygląda bardzo realistycznie ,jestem ciekaw ile bochenków chleba upiekłeś Uwe . Super to zrobiłeś. Pozdrawiam Mirek
Hello
The oven looks very realistic, I wonder how many loaves of bread you baked Uwe. You did it great. Regards, Mirek
We are all loving the weathered/post use soot look you have achieved!!
Thanks for sharing the photos...now you have to share the secret processes you used to achieve these superb effects!!
Like others, I was skeptical when you showed the original plastic pieces for the oven but you worked magic!
Many Thanks to @dockattner , @Jimsky , @HughLo , @shota70 , @Don Case , @pianoforte , @Herman , @GrantTyler , @Cathber , @Signet , @Mirek , @BradNSW , @GaryA and @pingu57 for the kind words and your interest and everybody else pushing the like-button
no real secrets - to be honest -> I used what I had and it worked somehow
The basic "red or occre colour were the ecoline colours - and the weathering was done with a set from Revell with six different pigment powders
The colours included are Mud Green, Dark Brown, Rust Red, Sand Yellow, Deep Black and Snow White - so everythinmg necessary to produce a dirty and used oven
also the top of the blackened smoke chimney was done .... the final installation will be done at the end - now only the two pots have to painted with copper colour
Many Thanks for your interest .... to be continued .....
Such beautiful work! I believe the stove's hood and stack are made of brass; what finish did you use to get the metal/pewter finish? It works SO well here.
