Thanks Bryian. Hopefully me eyesight holds out to get the rest of it all done.Thats some fine detail work there Steve, well done.
Fantastic work, Just catching up on your build. If I may comment and suggest. If you have not yet sealed you hull with the deck, it may be helpful to add some weight (I use BBs mixed with epoxy) in the bottom of the hull to give it a bit of heft. The hull is easier to handle if it has some weight. Also if you want to mount the ship on a stand, now may be the time to think about drilling some holes in the bottom to attach bolts to.Some fine PE
A venture into the some of the small, yet detailed, PE parts within the Pontos detail kit. Armoured deck boxes (32 pieces to make 16 lockers) and skylight hatches (x8)
Tiny in the grand scheme of things for this ship, but so time consuming. I think I need a new glasses script.
View attachment 445784View attachment 445785
Hi Rob,Fantastic work, Just catching up on your build. If I may comment and suggest. If you have not yet sealed you hull with the deck, it may be helpful to add some weight (I use BBs mixed with epoxy) in the bottom of the hull to give it a bit of heft. The hull is easier to handle if it has some weight. Also if you want to mount the ship on a stand, now may be the time to think about drilling some holes in the bottom to attach bolts to.
Using all the PE is indeed hard on the eyes, impossible for me. I have a pair of optivisors and find them invaluable.
There are many lower price knockoffs available but I don't know how good they are. Also when working with small items, a well lite workbench is essential.
Hey Harald,Hello again!
Lovely progress on your HMS Hood! I just got my first battleship as well, a USS Missouri, that I'll be getting the advanced Pontos set for. I was originally just going to do the decks, but Decided to go all in again!
After 2 moves, it will be time to pop the Titanic back on the bench, just finishing up an Airfix Sea King, that I thought was so lonely at the store...
For help (and company!) during the build, check out this channel on YouTube! The Model Shed, Steve, the owner, runs a tight ship and his build series of the Hood and Bismarck both in 1/200 are epic! I'd class him as a master modeler. I often have him running in the background on the bench whilst I fiddle with the finery of making models.
Cheers
Harald
I have 2 Optivisors...Both purchased at competitive pricing, both have plastic lenses, both hmmmm okay. Now currently saving all my pennies so I can buy an Optivisor with glass lenses that will give sharper and clearer definition of those tiny PE pieces. Cant bring myself to buy cheap for 'Aging eye sight'Hi Rob,
Thanks for the advice mate, but I had already sealed the decks. I will be building a stand for the ship, so that's also taken care of.
Yep, I have pair of optivisors as well, and agree they are great. Couldn't do a lot of the fine work now without them. Thanks aging eyeballs!
Appreciate you comments.
Yes, the Scaledecks look so much better. Good luck with that; no small task.Awesome! Thanks Steve. Just started back on mine after a loooooonnnnggggg hiatus. Am doing the decks right now, using te Pontos wood decks as patterns to cut the shapes out of the ScaleDecks full sheets. I prefer the multi-coloured look to the plain blonde.
