HMS Medea (28) (1778) 1/48 scratch build
It is special to use your own timber grown in your area - and it is looking very good Thumbsup
One step forward, two steps back.
I finally tackled the (to me) difficult task of fitting the stern frames. I should have built more support into them.
The next day I broke it all off when trying to fit more support...
More care, less haste. But still enjoying the challenges.
In case anyone is wondering, the blue panels along the deck line are to support the upturned hull in the clamp. I made pins that drop down into the mast steps and it is easy to manipulate the hull from upright to upturned as I work.
Making progress but amazed how much material this takes. I've just returned from the community workshop after cutting another stock of 1/4 x 1/16 planks so will get more done over the next few days. I have to start tapering the planks and inserting stealers now.
Now I am away from the braces between the frames I'm finding these stainless steel clothes pegs very good clamps.
Hopefully my Internet woes have been resolved and I can now continue with the build log.
80 grit sandpaper is my friend. Plus wood filler!!
Second sanding to reveal more gaps to fill.
Dampened with water to bring out loose fibres.
Just about ready to seal to protect hull while I continue with top works. Copper tape or plates to be fitted later.
Despite appearances the hull is now very smooth and I don't think it will need more than a light sand before sealing.
I've also been working on the main deck beams. I made a simple jig to hold the timber while I roughed the upper curve out with a chisel.
I cut a cross section of the plans to check the curve as I worked.
Then I sanded out the bottom curves with the dremel set up inside my work box with the shop vacuum cleaner attached.
Finally I hand sanded the beams to their final dimensions.
