HMS Ontario 1780 scale 1:32 POB full version
Yes Zolly,shape a piece of scrap wood to sit on the deck and against the bulwark.Drill a hole through the block at the required angle.You can then drill from inside using the block as a drilling guide.This is all dependant on how much space/angle you have to get the drill in.You may have to use a pinvise.I certainly would try and go from the inside out as going the other way you are asking for misalignment in relation to the deck;)
Kind Regards
Nigel
My concern is that the exit holes are not going to be lined up outside of the hull as maybe I won’t get the right angle for all the scuppers.
I hear you Zoly..., then, using the jig Nigel describes in previous post, drill the hole inside the bulwark\waterway just half way thru, and another hole outside. I suspect you will use copper\brass tube for the scuppers?
So a dummy holes both sides but not completely through and place blackened brass tubes in holes,not sure if they had tubes in there
Jim this drawing is for a modern steel-hulled vessel
Thanks, Nigel! Yes, I am aware that it is steel. I did find another sketch. While it doesn't belong to a specific ship, it does give an idea. Lead openings were used in 16-19th Centuries. Imitate with blackened brass is possible.
Hi Zoly I have used cable sleeves for this, these are from silver so you can color them with egg yoke to look like lead.
These are available in all different sizes.
The outside in my RC is fitted with carvings but guess that wont be the case in your man of war.
Hi ZOLY, I HATE TO GIVE SOMEONE AS GOOD AS YOU SOME ADVICE, BUT BECAUSE AT MY SKILL LEVEL I HAVE TO REMOVE ITEMS A GREAT DEAL, MY METHOD FOR BOTH CA AND PVA GLUE IS THIS GET SOME NAIL POLISH REMOVER IT MUST BE 100% ACOTONE USE A COTTON SWAB RUB IT ON THE JOINT AND CAREFULY WITH AN XACTO BLADE START PRYING IT LOOSE, YOU MAY HAVE TO DO THIS A FEW TIMES UNTIL IT COMES LOOSE, IT WILL NOT DAMAGE THE WOOD OR DISCOLOR IT, TAKE IT FROM ME IT WORKS HAVE A LOT OF EXPERIENCE WITH THIS. Don TRY IT ON A PIECE OF SCRAP
Hi Don,I have chosen not to remove the waterways ,I sanded it down to half thickness
Hello everyone ,I had a little fun cutting out this doorway ,first I drilled a bunch of holes inside the line then rest of the door and chipped the pieces of with a mini plier ,after I used my Permagrit files to sand it to the correct shape.
276AE687-3EF6-4850-BBC8-58B84E948CFC.jpeg072A91ED-8D1F-46F4-BD36-70D59751452D.jpeg255E9997-F758-4632-BD89-9D5370F8BD15.jpegA7327469-D389-462B-A0F8-BBC6447DEA4B.jpeg1DFAFE2A-E486-46F1-BAF2-6F0FF5F1971F.jpegE00FC445-5D12-4B52-B7AB-6EC80E3437B6.jpeg​
