HMS Ontario 1780 scale 1:32 POB full version
Hello Zoly, It is nice to see you back at your Ontario build again. Those thick planks will be slow going, but you are doing a great job of bending and fitting them. Are you using CA to fasten these bent planks?
Regards Lawrence
Hi Lawrence ,yes I am using CA to secure the planks ,the main glue is Pva though.
Hello Zoltan,
It took me some time to get in your “over-the years” scratch build-log. There is so much to see on the SoS. And took some time to walk through the pages. With the nice communication in the beginning to get started. The foam pre-build was interesting.
I am glad I am in on time to follow to the end ;).
Hello Zoltan,
Hi Zoltan, I aggree with Peter completely, wonderful work.
Greetings Zoly. Nice work!!
Given your position as a model, I would suggest the method I took to secure the boards with medical rubber. Simple, cheap, efficient. There is no risk of damage to the boards. Ondras :cool:
Thank you Ondras!I may use in some cases I can’t hold/secure the plank,I am using both Ca and wood glue
Thanks!
Hello Zoltan,
thanks Peter,I am a slow builder,this build will take a long time.
