Hello. This is still a schematic view. Later there will be a decor and a "roof" over the windows. And he painted the windows according to the model. Uwek is right, it is most likely not full-fledged windows, but ventilation windows. They fall on the cabins where the guns are located, and if there are ventilation hatches on the decks, then there are none in the cabins.Знову дозволю собі вставити 7 копійок:
Ствисти косяки вікон вздовж рельсів- варіант лепський;
Ствисти косяки вікон уздовж палуби- варіант реалістичний.
Також пропоную привернути увагу на якийсь "козирок" над вікнами:
Again, let me insert minor comments:
Putting window jambs along the rails is a beautiful option;
Putting window jambs along the deck is a realistic option.
I also suggest paying attention to a certain "canopy" over the windows:
Hello. I only use the Rhino as a base 3D model. I make a 2D drawing in CorelDraw. Maybe later I will create the whole ship in Rhino, for now I use it to create parts (lights, guns, anchor...).
Hi Anatoly,
I am following your lovely project with great interest and I see that you are also using Rhinoceros for 3D design. Do you use its "Make 2-D Drawing" command to convert your 3D design into 2D drawings? Or some other way?
I'm just asking this as this particular command doesn't work very well in Rhinoceros (which, apart from that, I like much) – because, upon applying it, it often 'loses' some lines and generates a lot of rubbish as well, which is quite a nuisance and complication in post-processing. Frankly, for my purposes, this "Make 2-D Drawing" command is so useless that I'm forced to disregard it altogether in favour of rendering a vector 3D design into a high-resolution bitmaps in order to get decent 2D views (orthogonal or otherwise). But perhaps there is a better way, the result of which is 2D graphics in vector format and yet of sufficiently good quality?
Ciao Alessandro.Ciao Webber007.
Finalmente ho trovato il mio maestro per imparare Rhinoceros.
Io tuoi lavori con 3d sono magnifici.
In futuro potrei farti delle domande specifiche su comandi e funzioni di Rhinoceros?
Hi Webber007.
I finally found my master to learn Rhinoceros.
Your 3D works are magnificent.
Could I ask you specific questions about Rhinoceros commands and functions in the future?
Привіт Анатолій.Винятково, якщо у вас є такі результати і ви тільки починаєте, коли станете експертом, я не можу уявити, на що ви будете здатні!Я думаю, що це думка багатьох і не тільки моїх.Дякуємо за вашу доступність.Зараз у вільні хвилини я працюю над рятувальними шлюпками. Я із задоволенням малюю їх сам.Коли я покажу проекти Rhinoceros на мою тему, я задам вам багато запитань, але якщо ви віддаєте перевагу, я задам їх у личку.Ще одна річ, яку я помітив, це те, що ваші 3D-принти не тільки ідеальні, але й гладкі.Усі ті, які я зробив, мають рифлені поверхні.Наприклад, деякий час тому я розробив деякі гармати з Rhinoceros, тому що жодної гармати з епохи, яка мене цікавить, не існувало і не існує на ринку (у модельних магазинах у Римі, але навіть не в електронній комерції).Тому я намалював їх, дивлячись на фотографії різних типів гармат Dahlgren, але без вимірювань вони не найкращі.Я дав їх другові на 3D-друк, і вони вийшли всі рифлені, а не гладкі.Ciao Alessandro.
Sto appena imparando Rhino, ma sentiti libero di fare domande. Se lo so, risponderò volentieri
Hi Alessandro.
I'm just learning Rhino, but feel free to ask questions. If I know, I will gladly answer
