I apologize for such a belated Happy Birthday, but I want to congratulate you on a magnificent lower hull planking. This came out really well!
What happens in Vegas...Are you speaking from experience perhaps? Just wondering. View attachment 341486
Thanks HH. As you know, Uwe always has the birthday thing covered...I apologize for such a belated Happy Birthday, but I want to congratulate you on a magnificent lower hull planking. This came out really well!
Never been there... I'd have to defer to you on that one, Paul. I saw all "The Hangover" movies. Care to share any spicy stories with us?What happens in Vegas...
Actually...I'm usually in bed by 9:00 pm...Never been there... I'd have to defer to you on that one, Paul. I saw all "The Hangover" movies. Care to share any spicy stories with us?
Impressive work and translucent painting. Is that an original Paasche Airbrush?.Well, it was time to try using the air brush again. Mine is an airbrush from 1987, given to me by a close friend along with an equally old compressor. The bottom of the hull was painted and lacquered. Then, the saddles were reinstalled on the baseboard and the model placed on them upright.
Materials for masking off the lower hull. The paint was mixed with airbrush medium to thin it out to the proper viscosity for the airbrush.
After masking, the hull is painted with a thin coat, allowing the plank seams to show.
Seams still visible. The airbrush applied paint in a much thinner coat than spray paint directly from a spray can. This will work.
Krylon Satin Finish is the lacquer I used to protect the paint. It adds a small amount of satin sheen to the hull.
Buttocks after laquering.
Letting the lacquer dry.
Preparing to reinstall the saddles so the model can sit upright again.
The saddles are reinstalled on the baseboard.
Progress so far. View attachment 341384
No, it was an old Badger airbrush, which is very common. I am new to using the airbrush and the mixture of medium and paint was only approximated. The tip of the airbrush clogged three times over the 3 hours I took to learn how to paint the hull as I went. I'm getting quite experienced at cleaning it.Impressive work and translucent painting. Is that an original Paasche Airbrush?.
Thank you. Possibly paint medium may have been too high a viscosity or solvent incompatibility usually helps clog nozzles. Regardless, you ended up with a very nice finish.No, it was an old Badger airbrush, which is very common. I am new to using the airbrush and the mixture of medium and paint was only approximated. The tip of the airbrush clogged three times over the 3 hours I took to learn how to paint the hull as I went. I'm getting quite experienced at cleaning it.
Since I was spraying more air than paint, the tip would slowly accumulate dry paint. The viscosity could definitely be off, because I literally dumped paint and medium into the spray bottle with pure guesswork, checking to see how thin the mixture swirled in the bottle, and it looked pretty thin. Paint was applied in very thin, misty coats, slowly fading the planking seams until they were barely visible. What too forever is inspecting and painting those area which were thin, and removing the blobby appearance of the overall coating. It looks even now, and a bit thicker, but the wood grain and seams peek through. It still looks like wood, and avoids the plastic, smooth appearance found on models made by builders who are more precise, careful, and experienced than I am. The lacquer coating hardened and protects the paint well from scrapes and dirty finger stains. I learned a lot from this paint job.Thank you. Possibly paint medium may have been too high a viscosity or solvent incompatibility usually helps clog nozzles. Regardless, you ended up with a very nice finish.![]()
Thank you for the summation. Cheers.Since I was spraying more air than paint, the tip would slowly accumulate dry paint. The viscosity could definitely be off, because I literally dumped paint and medium into the spray bottle with pure guesswork, checking to see how thin the mixture swirled in the bottle, and it looked pretty thin. Paint was applied in very thin, misty coats, slowly fading the planking seams until they were barely visible. What too forever is inspecting and painting those area which were thin, and removing the blobby appearance of the overall coating. It looks even now, and a bit thicker, but the wood grain and seams peek through. It still looks like wood, and avoids the plastic, smooth appearance found on models made by builders who are more precise, careful, and experienced than I am. The lacquer coating hardened and protects the paint well from scrapes and dirty finger stains. I learned a lot from this paint job.
Good morning Kurt. When you said you were going to paint that beautiful planking I was like “NO”. You pulled this off brilliantly and thank you for explaining the process. Certainly owned this. Cheers GrantWell, it was time to try using the air brush again. Mine is an airbrush from 1987, given to me by a close friend along with an equally old compressor. The bottom of the hull was painted and lacquered. Then, the saddles were reinstalled on the baseboard and the model placed on them upright.
Thanks, Grant! There is just enough paint to make it white without drowning out the wood texture and seams. This experiment was a success. Time to contemplate construction of the stern castle interior decks and how to merge them with the side galleries. La Couronne should have been white, but I left the mahogany planking alone on that model, so in the interests of historical accuracy in appearance, it was decided to paint this hull.Good morning Kurt. When you said you were going to paint that beautiful planking I was like “NO”. You pulled this off brilliantly and thank you for explaining the process. Certainly owned this. Cheers Grant
Hi Kurt, yet another great hack for making balusters.11mm Falkonet belaying pins used for the balusters.
Hacks are bread and butter for scratch building. I neatened up the and repainted a couple joined on the rails and straightened a few balusters. That assembly was very delicate!Hi Kurt, yet another great hack for making balusters.
True story
