It really is the same ship.I really like the tone of white in the first two pics of your post. The second two shots however seem to be much whiter?
I used a foam brush, and mix some black and some white enamel paint in paint thinner. After application, the grey paint congealed in seconds into a fine, spotty texture pattern. The remaining paint in the foam was squeezed out into a rag, then the texture was smeared along the plank lines with the moist foam until it began to dry, leaving the grey stained effect you saw in the photos. Basically, I was making it up as I went. Any attempts to add color to light areas after the wash was almost to dry cleaned all the grey off. After a few redo's (yeah, several redo's), the grey wash was consistent enough to be acceptable. What made it really difficult was that the painted surface was sealed with Krylon Satin Finish, so there were no pores left to hold the grey, so the grey sat on top of the finish and seeped into some plank seams that were still unfilled. Anyhow, it's as good as it's going to be.I do washes with a brush, more control on where you want to concentrate the darker areas. Consistency is not realistic.
On another note. I am familiar with drop planks at the bow, but have never seen more than one drop plank intersecting another plank. You had a plank that looked like a lightning bolt because it had multiple drop planks intersecting it. I am not sure this is correct? However I really like the end result, and painted it kind of disappears.![]()
Well I think you did a great job on all accounts! Keep up the good work.I used a foam brush, and mix some black and some white enamel paint in paint thinner. After application, the grey paint congealed in seconds into a fine, spotty texture pattern. The remaining paint in the foam was squeezed out into a rag, then the texture was smeared along the plank lines with the moist foam until it began to dry, leaving the grey stained effect you saw in the photos. Basically, I was making it up as I went. Any attempts to add color to light areas after the wash was almost to dry cleaned all the grey off. After a few redo's (yeah, several redo's), the grey wash was consistent enough to be acceptable. What made it really difficult was that the painted surface was sealed with Krylon Satin Finish, so there were no pores left to hold the grey, so the grey sat on top of the finish and seeped into some plank seams that were still unfilled. Anyhow, it's as good as it's going to be.
As for the drop planks, yes the expansion of the hull surface from bow going aft combined with the narrow 4mm planks made it necessary to splice in drop planks in close proximity. Hey.. it's only my second hull after all.![]()
Thanks buddy!Well I think you did a great job on all accounts! Keep up the good work.![]()
I asked Kris (@SZKUTNIK) not to send the second set of barrels if he hasn't started 3-D print them yet. Imagine how screwed up the post office will be come Christmas time. THANK YOU KRIS! These barrels are accurate to HMS Sovereign of the Seas in markings and size, and will going the following locations:| Quantity | Location from Bow | Gun Type | Actual Length | Desired Barrel Length 1:84 Scale (not including cascable) |
| feet | mm | |||
| Upper Deck | ||||
| 4 | Bow Chase | Fortified Demi Culverin | 10 | 36.2 |
| 6 | 1-3 Broadside | Demi-culverin Drake | 8 | 29 |
| 8 | 4-7 Broadside | Demi-culverin Drake | 9 | 32.6 |
| 4 | 8-9 Broadside | Demi-culverin Drake | 8.5 | 30.7 |
| 4 | 10-11 Broadside | Demi-culverin Drake | 8 | 29 |
| 2 | Stern Chase | Fortified Demi Culverin | 10 | 36.2 |
| Forecastle | ||||
| 4 | Bow Chase | Demi-culverin Drake | 9 | 32.6 |
| 2 | 1 Broadside | Demi-culverin Drake | 8 | 29 |
| 2 | 2 Broadside | Demi-culverin Drake | 8.5 | 30.7 |
| Quarterdeck | ||||
| 2 | 1 Broadside | Demi-culverin Drake | 9 | 32.6 |
| 2 | 3 Broadside | Demi-culverin Drake | 8 | 29 |
| Poop deck | ||||
| 2 | Broadside | Demi-culverin Drake Cutt | 6 | 21.7 |
| Total = 44 guns |
Sorry you had to do that extra work, Kris. Hope you had a good lunch, though!Ahoy!
The second set of barrels has been printed. If somebody needs...... in shipping price.
On the private order we can print hull (3D Print) for the model Sovereign of The Seas in every scale :--)
| Quantity | Location from Bow | Gun Type | Actual Length ft. | Barrel Length (mm) 1:84 Scale (not including cascabel) | Parts Storage Bin | Number of Carriage Trucks |
| Upper Gun Deck | ||||||
| 4 | Bow Chase | Fortified Demi-Culverin | 10 | 36.2 | 1 | 2 |
| 6 | 1-3 Broadside | Demi-culverin Drake | 8 | 29 | 4 | 2 |
| 8 | 4-7 Broadside | Demi-culverin Drake | 9 | 32.6 | 2 | 2 |
| 4 | 8-9 Broadside | Demi-culverin Drake | 8.5 | 30.7 | 3 | 2 |
| 4 | 10-11 Broadside | Demi-culverin Drake | 8 | 29 | 4 | 2 |
| 2 | Stern Chase | Fortified Demi-Culverin | 10 | 36.2 | 1 | 2 |
| Top Forecastle | | |||||
| 4 | Bow Chase | Demi-culverin Drake | 9 | 32.6 | 2 | 2 |
| 2 | 1 Broadside | Demi-culverin Drake | 8 | 29 | 4 | 2 |
| 2 | 2 Broadside | Demi-culverin Drake | 8.5 | 30.7 | 3 | 2 |
| 2 | Inboard Facing Aft | Culverin Cutt | 6 | 21.7 | Kit | 4 |
| Halfdeck | | |||||
| 2 | 1 Broadside | Demi-culverin Drake | 9 | 32.6 | 2 | 2 |
| 2 | 3 Broadside | Demi-culverin Drake | 8 | 29 | 4 | 2 |
| 4 | Inboard Facing Forward | Culverin Cutt | 6 | 21.7 | Kit | 4 |
| Quarterdeck | | |||||
| 2 | Broadside | Demi-culverin DrakeCutt | 6 | 21.7 | 1 | 2 |
| 2 | Inboard Facing Forward | Culverin Cutt | 6 | 21.7 | Kit | 4 |
Yes, I have to prime and paint them bronze.What's your plan for finishing the gun barrels? Were they bronze?
Looks good to me Kurt.I'm not a painting professional, and this work proves it. I was just making it up as I went along, but the results are good enough. I had three types of bronze spray paint to work with. After priming the barrels with acrylic primer using the air brush, I selected the paint can on the right since it seemed to have the best coverage and was dark enough. The one on the left had more clear varnish in it that pigment, and the one in the center was closer to gold than red bronze, but had good coverage. After spray painting 22 barrels of various sizes for the upper gun deck, a wash of brown and black diluted with thinner was used to further darken the barrels and bring out the details a bit.
Test sample each paint. I liked the one one the right the best. The center and right ones had visible metallic glitter in them, and the one on the left was drab and not very metallic, and had poor coverage with pigment compared to the others..
I already had some thinner polluted with brown paint, So I added two drops of black enamel and went with it for a wash.
Two barrels on the right have wash applied.
The barrels appear glossy, perhaps too much, but they'll work. The paint is still wet here, so the details look gloopy. After the paint dried, however, the paint coating thinned and the details became sharper.
