HMS Victory [1805] 1:79 by serikoff. Started with Mantua -> Upgraded with John McKay's Anatomy.
01.2010
To start, I hurried to ensure a place for the bowsprit so that it wouldn’t be loose inside but would have its designated spot.
I filled the lower part of the hull with balsa inserts. I pre-cut fragments of the appropriate size and glued them in layer by layer.
I made a small reserve (1-1.5 mm) to avoid depressions in the future. I aimed to keep the structure hollow for material efficiency and to facilitate the creation of a window at the level of the second tier of gun ports.
As a result, a sufficiently rigid structure was created. This principle will be applied to all further work on the rough sheathing below the plates that have already been installed.
At the level of the small front deck, the locations for the knight's deck are visible. I cut these parts out, as I described in the section on working with the drawings.
Currently, there are 400 parts on board, and the continuation of the sheathing will be in the next part...
01.2010
Hi Sergey
Probably it's too late at this stage but have you considered including lights in the various parts of the ship?
Welcome Sergey! I will now follow your construction here.
Приємно бачити земляків!!
Hi Sergey
It’s already too late for that, as the hull is completed and I'm currently working on fitting it out. I’ll give it more thought if I decide to build the next one as an admiralty model.
Hello
You've got yourself quite challenging project. Good job with this build log, going into details and describing them will be helpful for many.
I'm also pulling up a chair. You mentioned adding 3d parts, do you intend on changing dummy half canons for full scale with carriages?
Hello to all my colleagues in the best hobby in the world!
My name is Sergey, but in the world of ships, I go by the name serikoff.
And here’s my story. (Without this introduction, it might be hard to understand me).
I’m from Ukraine and I am the creator of a website and forum dedicated to wooden shipbuilding. My forum is one of the largest in Ukraine. It began functioning fully in 2012. There are more than 150 build logs, just as many threads featuring completed models, and 250 threads discussing techniques and other topics. Some of the modelers who have published their work include prominent names such as: Evgeny Epur, Dmitry Shevelev, and Vladislav Zhdan. These names are well-known in our region. (By the way, Olga, who is known here under the nickname shipphotographer.com, also regularly published her work. It’s not surprising, since we’re from the same area). But! The situation started to deteriorate after 2014, when we began having issues with the website’s domain and hosting. That was the first phase of the war, as our countries were closely intertwined, and cross-sanctions began to destroy joint services. And after the full-scale Russian invasion of Ukraine, the website essentially died. To be more precise, it still exists, but all the images uploaded by modelers have disappeared. The reason for this is a conflict between the image storage resources and the website’s platform. Right now, I don’t have the resources or time to restore it. But I’m sure that after our victory, someone will be able to create a forum as large and wonderful as yours.
Now, about me...
I started building my second model in 2009 (the first one was experimental, and I didn’t see the point in finishing it). At that time, there weren’t as many resources available as there are today. I made many mistakes and learned how to correct them. I shared this knowledge on my website and forum. However, due to being busy in 2013, I had to put my project on hold. But as the saying goes, "Every cloud has a silver lining." The war started, borders were closed, and I could no longer travel—something that took up all my free time. I’m a dentist, in case anyone’s curious. And under constant shelling, explosions, and air raid sirens, to keep from losing my mind, I decided to return to my hobby. Exactly 10 years later.
What am I doing here...
First of all, I’d like to say that I found your forum by accident. But! I fell in love with it right away! There’s a warm atmosphere, lots of information, and I’ve really been missing all of this. In my journal, I want to share my build, all the knowledge I have, and, of course, ask the questions that interest me. I will be happy to help anyone if you have questions, feel free to reach out. I’m deliberately not posting a link to my website so as not to spoil the build. I want my journal to progress in real time, reaching the current state of the build. Please excuse my English—I will be using Chat GPT for translations to avoid any difficulties.
What I’m building...
As you can see from the title, it’s HMS Victory. I created the framework of the model using plans from a Mantua kit. I didn’t buy the kit itself. I printed the plans in A0 format and built the frame (the skeleton) based on them. That was the end of my work with the Mantua kit. All further work was based on John McKay’s anatomy of the ship. In this journal, I want to take you through the whole process, from the kit plans to the anatomical upgrade.
I would also like to share my experiments: Working with blueprints. Aging and painting wood. Aging copper. Making and painting ropes and rigging. 3D modeling and integrating 3D printing into wooden shipbuilding. And much more. It will be fun, and I hope it will be informative for you. I’m sure I will learn a lot from you as well. Thanks in advance for that!
Let’s get started!
P.S. Рідною.
Хочу звернутися до всіх українців, що виїхали до, чи під час війни. Не слухайте нікого. Кожна людина прагне щастя та безпеки собі та своїм близким. І я щиро сподіваюся, що у вас все добре і ви у безпеці. А всім, хто залишилися, хочу побажати перемоги, мирного неба, сил та здоров'я все це пережити. Бережіть себе, все буде Україна! Слава ЗСУ!
Так Ласкаво просимо -))
Дякую))
Hello
Thank you for the high praise. I believe my build log will be helpful to many. Due to some translation difficulties, I didn't fully grasp your question, but based on my understanding, here's my response. Later in the log, I’ll be describing how I modeled various ship components in Blender, such as cannons, carriages, the ship's wheel, intricate columns, and many other details that are difficult to craft at a small scale. All these parts will be painted, so it won't be noticeable that they’re not made of wood, which is the intention. But to avoid spoilers, I’ll cover this later in the log.
If you have urgent questions on this topic and can't wait, feel free to message me directly, and I’ll try to help. Alternatively, you can wait until I reach that point in the log. Since this is a large topic, I might even create a separate thread that I'll run in parallel. That thread will be in the 3D modeling section.
Part 4
10.2010
My entire build progressed in intervals. There were times when I would work non-stop for days, and then there were long breaks. After the first major pause of about six months, I resumed planking the lower part of the hull with inserts. The inserts were made of balsa wood. This wood is easy to work with yet strong enough to withstand sanding without warping.
Step by step, all the gaps were filled.
After completing the filling, I covered the large openings with tape and began shaping this faceted structure into smoother, rounded forms.
This was just an intermediate step before the puttying and final sanding. However, even at this stage, I was already satisfied with the result.
The hull now consists of 700 parts and weighs over 2.1 kg—definitely not something you can carry around for long!
10.2010
The rough planking is nearing its logical conclusion, and before temporarily installing the decks, I decided to center the masts. For now, they are just for fitting purposes. I'd like to remind you that a warship’s masts have different inclinations: the foremast is at 90 degrees, the mainmast leans back by +2 degrees, and the mizzenmast leans back by +3 degrees. The bowsprit is angled 30 degrees upward in relation to the waterline. Unfortunately, this important detail is often overlooked in many kits!
Regarding the ship's longitudinal axis, all parts of the rigging must be perfectly vertical.
After ensuring that everything was aligned properly, I proceeded to work on the decks.
10.2010
The middle deck will be removable. Therefore, I prepared special slots for it to fit into securely.
In the middle section, I made a cut in the deck and designed it to be composite. A small part will be fixed to the hull, while the larger part will be removable. Later, it will become clear why I chose this approach.
I added curvature to all the decks with internal inserts, as shown on the upper deck.
Side supports were also made for the upper deck. They serve as a small railing.
This huge stage of the rough sheathing is complete. Ahead lies the fixation of over 100 gun ports. It will be a long, monotonous task before the smoothing and sanding of the hull.
There are 720 parts on board... Let's continue!
Part 5
10.2010
To avoid delaying the process, while there's time and motivation, I’ll be accelerating the submission of new material.
Before diving into the repetitive work with the ports, I tackled a few other tasks. I calculated the rudder area.
And I finished the work on the inner side of the hull.
But for the production of the gunports, I needed the final finish wood. I didn't want to paint the ship yellow, so I initially searched for wood with a pleasant natural color, close to an orange-yellow hue.
After some time searching, I came across a few parquet planks made of a wood I had never even heard of before. It's called Daru (or Garu). Incredibly dense, almost like stone. When working with it, the wood had a wonderful scent, so much so that it was a real pleasure to work with. The color varied between the different planks, which allowed me to play around with combinations to create an interesting look.
The second discovery was pink pearwood. It was exactly what I was looking for—a dark, rich color that completely captivated me. And just to jump ahead a bit, in 15 years I haven’t found anything quite like it. Since I didn’t have much of this pearwood, I decided to use it only for decorative elements, railings, and similar details.
The color turned out like this after applying oil. And again, looking ahead, I regret not leaving gaps in the planking. It would have looked really good. I thought I could carve out those gaps later, but once everything was glued, I realized it was impossible without having beveled the edges beforehand.
So, I cut the blanks for the gunports and began working on them. First, I set the horizontal level.
Then I cut the walls, glued them together, and attached them to the hull.
And I repeated this process over 100 times! )))
Then I created a port with a window. However, I should mention that I will redo it because I am not satisfied with the result at the moment.
From this angle, it has such a cute little face with a smile.
In total, I spent about 20 days working on the ports, and finally, everything was ready.
And all that was left was to putty everything and perfect the outlines.
10.2010
But before that, it was necessary to close all the ports to prevent dust from entering the hull.
Next, I applied an even layer of wood filler to the hull and then shaped it to the desired profile.
On top, I marked the lines for the hull planking.
I want to respond immediately to all those who are skeptical about this, specifically regarding the thickness of the layer of putty. To jump ahead, after 14 years, not a single planking strip has come loose. There are no raised areas, no cracks, and no steps. Everything is holding very securely. I glued the planking using PVA with the help of an iron, but I will discuss that later.
The work on the rough draft has come to an end. The model has just under 1,340 details and weighs about 2.4 kg. Ahead lies a very labor-intensive, important, and responsible stage – the final planking of the hull!
Part 6
11.2010
Before the planking, I secured the stem. The only thing is that significant adjustments will be made to it. For now, it’s as it came in the kit, but later I will shape it according to the anatomy.
I also finished the rear part.
02.2011
So, after a short break, I took out my old saw and began cutting strips for the planking.
Since I didn't have much Daru, I used birch for the inner layer of velvet and for the planking below the waterline.
For the first layer of planking, I made a layer under the velvet. This layer will be covered with black paint, so I used Daru with a pattern that I didn't particularly like. The one that was very beautiful I used in the area that won't be painted.
I preheated the strips with an iron to bend them to the desired profile.
To avoid waiting too long for the glue to set, I used the method of "welding" the strips with an iron. The principle is quite simple. PVA glue is applied to the strip, then it is positioned and pressed against the surface with a hot iron. After a few seconds, the glue heats up and "welds" the strip to the surface. The same method can be used to detach it. Therefore, when using this method, you need to listen for the hissing sound to determine when the strip has adhered properly. If you leave it too long, it may come loose again, and if you don’t leave it long enough, it won’t stick. The skill comes with experience. However, it is a very effective way to quickly adhere strips.
All the strips were glued using this method. Starting from the bulwarks down to the underwater part, which will be covered with copper sheathing, and continuing throughout the entire hull, as described below.
05.2011
Slowly but steadily, the sheathing progressed, and by summer, I had covered the entire underwater part.
This is not the final sanding yet; everything will still be refined to perfection. There was a small defect in the rear part, but I fixed it. Since this will be painted, I didn't redo everything but only addressed the indentation.
There are 1,700 details on board... let's continue!
I believe originally was a gunport with sideways opening covers, but be sure to check because I can't find a reference right now.
Yes, this is a window with two doors. It's small for a cannon, likely serving a viewing function or ventilation. Although it's possible that a barrel could fit there as well. I plan to redesign this window according to the anatomy.
Part 7
06.2011
As I mentioned, I made the bulwarks in two layers. Where the edge could be visible, I glued Daru, while the inner layer was entirely made of birch.
09.2011
After finishing the preparations, I once again started preparing the strips.
Then I glued all the remaining barhouts in the same way, specifically their inner layer.
I tried to work from both sides simultaneously to maintain symmetry.
09.2011
For further cladding, it was necessary to pre-make the blocks located inside the hull. From the photo, I think the principle is clear.
The strip marked with a pencil is a temporary strip. It will be removed after sanding, and a rail will be glued in its place.
Step by step, I covered all the space under the rails, and after that, I could sand everything down.
I would like to clarify once again that the light-colored strips marked with a pencil are temporary strips. They will be removed and replaced with the railings, as well as the scrolls and thin decorative strips.
Today is an exclusive date: 11.11.11 at 11:11:11.111. There haven’t been as many ones since the year 1111! Did everyone manage to make a wish?
Now, back to business. I have finally finished the cladding on the second side. Now there are 2,135 parts on board.
After sanding, I could install the outer layer of the bulwarks.
After nearly 10 months of pause, I’m back.
Regarding the barhoots: the upper ones are straightforward—three planks, each 4 mm thick. The middle barhoots consist of two parts. The upper part follows the principle of the upper barhoot (one plank, 4 mm thick), while the lower part is a locking piece. This part is slightly thicker, creating a small step with the upper part, measuring 9 mm in thickness. The lower barhoot is similar to the middle one, with one 4 mm thick plank on top and a locking piece below. The only difference here is that there are two locking belts. After the last one is mounted, everything will be sanded down, and the cladding will acquire a distinct texture and relief.
10.2012
After a long and dusty work of sanding the surface, I finally finished the final cladding. Well, almost. I took the model outside into the sunlight and took several photos with the best possible white balance. And here’s how beautifully the Daru looks in high resolution... I like it, do you?
This is not yet the final sanding, but I couldn't wait to show the result! :p
There are 2,300 parts on board... to be continued.
I forgot to clarify the dimensions of the future model. The image clearly shows all the proportions. A few words about why I chose such an unusual scale, 1:79, and why it differs from the standard kit scale. This is because I printed the Mantua blueprints on A0 format, calculating the dimensions to achieve the length I needed. As a result, after adjusting the finished hull size to match the anatomy, I printed the blueprints from the anatomy book in full-scale. So now, I can say with certainty what the final size of the ship will be.
