HMS Victory by Y.T.- Mamoli - 1:90 scale
If you're ok with the wheel dials, great, but for me and my eyesight, I found the DRO (Digital Read Out) an incredible option. Have fun with them.
Yes. I am OK with hand wheels. They are resettable to zero by the way. For type of work I do for wood ship modelling it is more than enough. But I was able to make even something more. I made a mini steady rest with intension to use it for masts, which I probably will never use.
See attached.
Did you make the band around the dead eye or did this come already made?
I may have just answered my question about the deadeyes in looking back at your very first post. This is the same model I built and am using it and the plans to complete the cross-section model I am currently working on. I don't like the ones supplied with the Corel kit so I'm looking for aftermarket ones (Cornwall Models and Dry Dock are both out of stock) or scratch building them.
Another question: did you make these hooks or buy them as aftermarket pieces? If you bought them, can you tell me what vendor you purchased them from? I need 12. Thanks
Whether you need just hooks or rigging blocks or you may need other aftermarket parts for your ship modeling, you can check out DryDoc Parts
All are different sizes as per drawings. Here we have the main stay and preventer stay ropes for fore mast and main mast.
I always make them.
The fore and main stays before applying to the model. Took some real struggle before I managed to make them.
These are very nice. I am working on a way to simulate these four stays for my cross-section, I first tried wrapping 1mm cord around a "Gorilla Glue" coated #18 gauge wire after making an eye splice in the end of the cord. This did not hold up although it could have worked. I am going to try this again but using a different material instead of the #18 wire. I will also forgo the eye splice as it is not worth the frustration. Good luck when you start to snake these stays after you install them.
