The question is not easy to answer without all the details. However, what I can observe, is the fact that your mill doesn't have a stationary head, and you attach the Dremel rotary tool.OK LET ME TRY TO EXPLAIN MY QUESTION, HERE FIRST I DO NOT OWN A PROXXON MF 70 MILL, JUST THINKING COMING TO TERMS WITH AGE AND EYESIGHT, I HAVE A VANDA-LAY MILL WORKS OF A DREMEL JUST OK WHEN MILLING FOR KEEL NOTHES I SET THE Z AXIS FOR THE NOTCH CAN NOT KEEP THE DEPTH OF CUT THE SAME DEPTH ESPECIALLY WHEN HAVING TO MOVE THE PIECE THAT IS WHAT HAPPENED ON THE LE ROCHEFORT SO NOW GOING TO A LOT OF SEMI/SCRATCH BUILDS AKA KRIS FROM POLAND SO NOT TO SURE WHAT I AM GOING TO DO THAT IS THE QUESTION HOPE I AM EXPRESSING MY SELF BTW DON ROBINSON ANSWERED MY QUESTION IT MAKES SENCE TO KEEP TRACK OF THE ROTATION ON THE HANDELS. GOD BLESS STAY SAFE ALL DON
- First, make sure the Dremel tool tightened in the mill housing very tight and perpendicular to Z, Y table at 90 degrees
- Make sure the collet for the size of your end mill, and also tight firmly
- Tight the milling part on the table: Here we have to know whether you use a vise or holding clamps. No matter what do you use, you have to tight the part 90 degrees to the Z column.
- All work should be done by one installment e.g. if you doing the keel notches, tight the piece from both ends on the X table, set the deep for the notch, and operate only on X and Y handles until you make all the notches.
