I bought the drill from kamiya USA p/n#74041 $35.00
It is a kit that must be put together much like a model.
N
Kudos to you Will. A very brave undertaking. Cheers.Well one thing I've learned is "procrastination doesn't lead to completion" so I started the under deck structures. I have a copy of the Hasegawa detail up super set instructions (many thanks to NMBROOK) to compare with the SSmodel PE. Without a common system to find the parts (SSmodel is 12 PE sheets and appears to include Hasegawas A, B, C and super set) I had to search until finding the needed part.
This is enlarged image of Hasegawa instructions showing the parts needed for the read deck
SSmodel PE which is on sheet "E". Fortunately is seems that parts are grouped on individual sheets rather than helter skelter. You can see the numbers don't match Hasegawa numbering.
Finding the parts necessary to start the structure the fun begins.
Probably i would replace the whole platform not just the supports using a thinner material like 0.30 - 0.50mm plastic stripNeeded to take a break from the lattice PE so I went back to the plans completing the fore structure. Before adding the structures I completed the fore deck fittings. After adding the fore structure some decks were added with a few ladders and doors. I saw a beautiful Akagi model by NSBROOK that had PE gussets under the extending decks so I bought IJN gussets from Flyhawk Model PE. Both with holes and without were offered so I bought with holes.
Adding the PE gussets required removing the moulded gussets as shown in the below picture.
With the gussets removed the fore structure extension decks were added along with the PE doors and ladders. Once the gussets are added the railing will be added.
View attachment 387942View attachment 387943View attachment 387944
Next is back to the flight deck lattice structures.
