Wow, fascinating watching all the pieces come together.
Jan
Jan
Hi John,View attachment 237154
This shows the build up of the superstructure, everthing went together just perfectly,
this when you need a few clamps,
the only things that had to be trimmed were the window panels,
well this is where I am up to at the present, so things will slow down a little from now on, there is a lot of filling and
sanding to smooth and blend everything in together,
again thank you for visiting my build,
best regards John,
I have not seen plastic work before and am interested in following the melding of wood and plastic for this model The photo of the finished one is a great insight to where you will be heading. Nice work. RichHi John,
I hope you have fully recovered.
Lovely looking build, should make a great working model.
Cheers,
Stephen.
o
Thats what Pat said,he was going to leave it un painted,This is a very nice therapy, pitty you have to paint it. I would screw it up by painting it![]()
...agree with Pat, I would leave it unpainted.Thats what Pat said,he was going to leave it un painted,
With the narrow flange piece I though that you had used resistance soldering to place it without visible overflow of the solder. Neatly done., I respect those of SoS with metal machining abilities. Rich (PT-2)Here is the winch, its not any particular winch, just something I made up from stuff in my scrap box,
I turned up both the side drums at the same time, its easier to keep a visual check on there size,
I had already drilled the hole through the centre for the main shaft to go through,
close up view,
over the years I have collected all sorts of cogs and bits of brass and copper, the large nylon cog
came out of some printer,
its a non working winch, nothing is soldered, it is all super glued together,
I super glued some square brass supports to the copper base on the inside, then I glued the sides to it
and then added another piece of brass support to the outside, you can see another nylon and aluminum
cog in the background this is what I turned to size for the lower cog, I was lucky with the upper it was
just the right size,
View attachment 237415o
after bending the winder I added a brake drum and some reinforcing trim over both sides and drilled
six holes for fixing in place,
then I added a locking handle,
all Pat has to do now is paint it, it was a nice relaxing bit of therapy for me,
thanks for looking in,
best regards John,
Thank you for the nice comment, I bought mine from Germany, I think it was approx $350 including postage and took two weeks to arrive, a good deal,Looking really good, makes me even more keen to acquire a Krick kit.
Pleased to hear the new sander performed well, at that price it has to be a bargain I think I will get one.
