La Belle - Caf Model 1:48 by Thomas Marocke [COMPLETED BUILD]
Construction of the staghorns or kevels.
In the kit are the parts from cherry and plywood. On the top right of the picture a cleaned version.
The horizontal plate should still be closed with a bar, like in the picture. The plywood can also be stained in cherry. Modelers without any experience will gratefull accept these parts.
My extensions are in pear. Therefore I have to build the staghorns myself.
Saw out and file.
SANY0847.JPGTop left first try with heart glued on. On the bottom right side thicker heart like on the Hermione.
The boudriot hearts were drawn somewhat flat. On the Hermione I had seen beautiful round hearts, which are also easier to drill without drilling through them.
Drilling device for horizontal wood with ground angles.
After the first drilling, the underside of the board to be drilled is turned upwards and again by 180 degrees. In this way both drillings are done with one template.
Now file the drill holes squarly.
The heart with drilling template with angles.
If drills are not clamped briefly, they bend and drill incorrectly. Therefore I drilled with a milling cutter.
Left staghorn after Hermione, right after drawing from the Boudriotplan.
The staghorn is not yet glued and already holds and fits like one piece without gaps.
The next days I have to make five more pieces.
With best regards
Thomas
Saw out and file.
View attachment 180959Top left first try with heart glued on. On the bottom right side thicker heart like on the Hermione.
With best regards
Thomas
Really well done. The finished staghorn is quite nice. The color and grain makes me guess walnut? If so, great job on your final sanding, no "fuzzy grain hairs"!
Assembly of the staghorns from pear wood.
The six staghorns ready for assembly.
Angularity control on a testboard.
Starboard.
Port side.
You may have noticed that I always use spacers. They are almost as helpful as a good construction plan.
Port side ready.
And the finished starboard side - the chocolate side.
I thank you for your kind comments and wish you a happy modelling.
With best regards
Thomas
Hallo Thomas,
once more, and sorry that I repeat myself also once more...... It is looking very good
Such spacers are helping that you get everywhere the same and correct height.
In our models sometimes 1mm difference can be easily seen -> Thumbsup
In many model kits the boats are missing and have to bought separately. I waited for a long time, but there was no suitable boat for the La Belle. So you have to build the boat and the stand yourself.
Upper boat-chock in the middle, lower boat-chocks towards bow and stern.
In the boat-chokes are the hollows for the reserve yards and topmasts.
Now the boat finally has a secure footing.
With best regards
Thomas
Many thanks for the birthday wishes!!!
After two weeks of back pain I could finally build again.
Main topsail sheet-bitts with holder under the deck beam. The roles are only imitated and were probably also on the original made of wood. They are so small that it was not worth turning them on the lathe.
With best regards
Thomas
The construction of the pumps.
Sawing the conical pump tubes.
Filing the square to 45 degrees.
First try attempt to build the lever holder from three parts. Disadvantage: each holder must be made three times.
Second attempt to build the holders from one piece.
The middle holder is the sandwich holder.
All parts of the pumps.
Put some glue under the tire and then push the tire onto the glue.
The mounted pumps.
View under the ship.
Slowly the deck is filling.
With best regards
Thomas
It was time to be a blacksmith again next to the carpenter. The foot for the mizzenmast was built.
Wooden parts.
For the tire of the mast copper was used.
By a short annealing the copper becomes soft and can be bent well. After bending it is again as tough as before. After heating, put it in vinegar for 20 minutes, then clean it with water, blacken it and wash it again with water. Wipe again briefly with a cloth to remove any black dust that might contaminate the wood. Cold formed brass can crack later, therefore copper.
With best regards
Thomas
