Thanks for the hint Uwe, good idea, I will add to it.Looking very good - well done my friend
Only one small comment:
not completely finished- there is the small metal (half) ring missing which fixes the mast of the boat
OK - This is working in the configuration like you made for the first anchorGute Frage. I did not change anything on the stock, I filed out the hole at an angle so that something similar to a slotted hole is created.
When the stick is through the hole and around the corner, it covers the slotted hole so that you can no longer see it.![]()
Yes Uwe, for the second anchor I plan the same like you.OK - This is working in the configuration like you made for the first anchor
I plan to install one anchor hanging at the cathead like this example
