Le Requin-Zebec-1750 POF 1:48 (ZHL)
Welcome abord Jim, if I had to choose between a brand-new Porshe or a well-done Resto mod 1970 Dodge Charger, well it's the Charger hands down.
... I was talking about the smell, ONLY :cool: Frankly never smell the well-done Resto, 1970 I assume, it will not get the scent smell of a new car. But the new kit smells.... oh yeah!
Welcome aboard Tobias, I have heard the stern grill extension isn't correct, I will be researching to find the correct configuration if one exists. I assume the data must be somewhere or how else would one know the kit isn't correct.
Hello Daniel,
here you can find some information, I hope this helps a little.
I think Rüdiger @Lucius and Karl @Jeronimo will be happy to answer any questions you may have and help you.
I will be pulling up a seat in second row, as not to block Paul and others view.
Nothing I like better than watch others have fun building a new and exciting project.
Maybe a set of long keel clamp boards on your support base to help keep the keel straight and on track.
Hello Daniel,
Thank you Tobias, this will really help save some time.
Theres plenty of room on this gigantic ships deck.
I hit the ground running this morning by spending a couple hours studying the plans, making some translations and setting up the ships jig. A stable straight keel is paramount to success here. I've been warned about vertical keel warping so we shall see.
The ships parts design and construction are almost identical to my YQ Bluenose, I have to wonder if they actually put the kit together, if so, there is no room for error. For those who are staring out like me, the keel has a built-in rabbit once you put the keel together in the 'sandwich' style as shown in the next picture.
This ship at 1:48 is HUGE, I didn't realize how much room it's going to take up. I will be reorganizing my shipyard in the near future to accommodate it.
Thank you all for all the helpful suggestions coming in, I love how this build is starting out.
Till next time!
View attachment 506880View attachment 506881View attachment 506882View attachment 506883
Till next time!
Good afternoon Daniel. Good thinking. Those are some serious bolts you haver there:D. Coincidently I was setting up my center timbers and bolting them to the jig base this morning as well. I agree with you that it is worthwhile adding some bolts etc to get this set up 100%. Cheers Grant
Good afternoon, all. I have spent about 4 hours setting up the jig, this was after I finished the keel assembly. The jig has 4 levels for fitting the ribs into but after you set the first lower layer, you have to set the keel in then finish the jig construction around it. I spent quite a bit of time fine tunning verticle as well as horizontal alignment. There are 90 notches that have to line up in X,Y,Z directions. Check it out.
Next comes the stage of very slow progress de-charring the multipiece ribs, who knows 5,000 hours should do it ROTF Explosion.
I will post periodic updates of stacks of frames.
Thanks for stopping by, have a great weekend.
Ugh, looks like a complex jig. Your translator app must be working overtime.
Jan
I have used the translator a little but mostly just following the pictorial that shows each stage of development. The translator will come in very handy when trying to identify the ships fiddly parts, especially when I purchase certain aftermarket items such as fittings for the rigging, or line sizes. Having built the POF Bluenose will play a huge roll in what needs to happen on this ship.
