Piatto sul Ponte? Flat on the deck?Dovrebbe essere al contrario
This shows flat. Unfortunately, the ZHL kit has the bulkhead raised here, not like the museum model. I assume I must cut through the railing and bulkhead to make it lie flat on this model.
la ringhiera no tagliarla ,vedi se ci sta spazio sotto la ringhiera poggiandolo sulla paratia leggermente inclinatoQuesto mostra piatto. Sfortunatamente, il kit ZHL ha la paratia sollevata qui, non come il modello da museo. Presumo di dover tagliare la ringhiera e la paratia per farlo stare piatto su questo modello.
These pictures show the cathead lying flat on the deck.the railing does not cut it, see if there is space under the railing resting it on the bulkhead slightly inclined
se non c'è troppo spazio facci un po di scarico sulla paratia, mi dispiace che non ho i disegni del Tuo Kit per aiutare di più ,vedi fotoQueste immagini mostrano la testa di gatto distesa sul ponte.
Vic, not sure I understand how this jig works. On the left, you have to set the size of the stacions. On the right, you have to feed the stock until it gets to the jig, and cut. Am I on the same sheet of music as you?Miter jig to help keep stanchions at the same height
Jim, I cut a piece at the correct length. Then, I placed a longer piece to butt up against it and clamped it down with a clamp. Afterwards, all I had to do is insert an uncut piece and place it against the clamped piece and cut it. All the new pieces are now the same size. It worked beautifully. I thank you for the earlier suggestion. I just did it my way.Vic, not sure I understand how this jig works. On the left, you have to set the size of the stacions. On the right, you have to feed the stock until it gets to the jig, and cut. Am I on the same sheet of music as you?
Thanks, Grant. But this last picture is not my ship. It was an example of @paulb, who also built the SR. I was just doing research on how others did the cathead on this model. I need to go back and see how they looked on real ships now.Good morning Vic. I think you got these catheads really good. It is so good to see an extended picture of of your ship. Sometimes we keep showing macro pics of what we do we forget to step back and admire. It really looks beautiful. Well done.
Ahhh- that is funny. Sorry Vic. He did an magnificent job Paul. CheersThanks, Grant. But this last picture is not my ship. It was an example of @paulb, who also built the SR. I was just doing research on how others did the cathead on this model. I need to go back and see how they looked on real ships now.
I agree. His build is an inspiration. I cannot attain to his degree of skill.Ahhh- that is funny. Sorry Vic. He did an magnificent job Paul. Cheers
That makes two of us...but we have loads of fun tryingI agree. His build is an inspiration. I cannot attain to his degree of skill.
I think I know who's the cat he\she is. Because of the Russian officer Navy hat, It does look like a cat of a modeler @dantist sovereignSo, this is what I found when googling cathead pictures.
I've seen his work!I think I know who's the cat he\she is. Because of the Russian officer Navy hat, It does look like a cat of a modeler @dantist sovereign
Is this your cat, @dantist sovereign ?So, this is what I found when googling cathead pictures.
