How you doing Vic- yep my least favorite job- rigging the cannons, and you also put in the metal hooks etc- awesomeRigging guns. It is so tedious working with 2 mm blocks. I need smaller hands. View attachment 291346View attachment 291347
looking good.Mass production on the rope coils. More efficient than doing them for each cannon separately. And I can standardize them better. When doing onsey twosies, I tend to get invested in them. Now I don’t feel so bad about just throwing one away and starting over because I’m making a bunch of them. View attachment 291999
Looks niceMass production on the rope coils. More efficient than doing them for each cannon separately. And I can standardize them better. When doing onsey twosies, I tend to get invested in them. Now I don’t feel so bad about just throwing one away and starting over because I’m making a bunch of them. View attachment 291999
Hello Vic- again clever thinking.Pin installed to hold the gun in position on the deck. View attachment 292456
I ran into that on my Black Pearl, which I coated with tung oil. Super glue just wouldn’t stick. I’m also using pins to help hold my bits.Hello Vic- again clever thinking.I wish I had some this with mine as I applied poly to my deck and the dab of glue I placed on my wheels is already not holding on some- I will remember this in future.
My favorite is when a piece gets loose from the hemostats and bounces off the walls.Back to drydockmodelsandparts.com to order more 2.5mm blocks so I can finish my guns. I must have lost 8 of them in my carpet.
Where is the dislike button?My favorite is when a piece gets loose from the hemostats and bounces off the walls.
Hello Vic,Rigging guns. It is so tedious working with 2 mm blocks. I need smaller hands. View attachment 291346View attachment 291347
The rigging is different for continental guns (ex: French) from the one you are working on. The recoil rope goes through the carriage frame and they use two rope/block rigs to pull it back to reload.Hello Vic,
concerning rigging guns I would like to draw your attention on my build log of the USF Confederacy
Greetings Werner
Werner, you have done a fine job with your Confederacy.Hello Vic,
Greetings Werner
Thank you very much!Werner, you have done a fine job with your Confederacy.
