Good afternoon Vic- I wish, Been working for a change.Thanks, Grant! Been enjoying the great outdoors?
Nice ones. I’ve been looking for some examples, Phil!
Oh, yuck!Good afternoon Vic- I wish, Been working for a change.![]()
Show off!
Whew...After multiple failed attempts, I finally got a strake down on the lifeboat. I even broke a couple of ribs and had to glue them back together. In addition to discovering the base form, I kept bending and shaping the plank until it matched the curvature of the ribs more closely. It’s not like the Galilee Boat. The strongback frame on it could take the tension from imperfectly shaped planks better because it was sturdier. View attachment 300633
I don’t know about comfort. It is a bit of relief to make it right, though. I guess it does encourage some too. I had dreaded going back to the lifeboat for two days. In fact, I avoided the shipyard entirely. I guess I just needed to step back, take stock, and think about it for a while.Now your lifeboat is taking shape.
It should give you some comfort (hopefully) that you're not alone in the breaking parts department; all too frequently I find myself with two rather then one part...
That brings back bad memories of me building my lifeboat on the BP, I was so glad there was only one to do.After multiple failed attempts, I finally got a strake down on the lifeboat. I even broke a couple of ribs and had to glue them back together. In addition to discovering the base form, I kept bending and shaping the plank until it matched the curvature of the ribs more closely. It’s not like the Galilee Boat. The strongback frame on it could take the tension from imperfectly shaped planks better because it was sturdier. View attachment 300633
Hi VicI don’t know about comfort. It is a bit of relief to make it right, though. I guess it does encourage some too. I had dreaded going back to the lifeboat for two days. In fact, I avoided the shipyard entirely. I guess I just needed to step back, take stock, and think about it for a while.
Looking like a nasty little build, requiring all your attention and expertise... Good luck!I have to say, building the lifeboat is so similar to the Galilee Boat. The experience I have gained there at a larger scale is transferable to a large degree to the lifeboat. The strakes do require a greater degree of beveling to keep the strakes flush with each other, and the tapering is on the bow instead of aft. It’s still not where I’d like it, but it is doing better. View attachment 300883
My opinion is possibly not historically correct, but I think it's more than likely that the rudder would be kept inside the lifeboat; the rudder is way too vulnerable for the hustle and bustle on any sailing vessel. From days gone by; my parents had a small, roadable sailing boat. Whenever it was on the road or in storage, the rudder was always secured somewhere in the boat. The rudder only got attached when the boat was off the trailer in it's element.Any ideas on which is more historically accurate or practical?
