LONGBOAT for La Salamandre in 1:48 (CAF)
Uwek
Administrator
Administrator
Vienna, Austria
After a longer period not working on my 1:48 La Salamandre (see link), I restarted the activities in the workshop with a small project in the project.
Within the kit of the bomb ketch, two boats are included. A cutter with 13 cm and a longboat with 16,8 cm.
Both are small POF models and are also available alone, therefore I started a new small building log for this boats.
NIDALE-model-Laser-cut-wood-Antique-Ship-model-kit-Sacle-1-48-La-Salamandre-Ship-s.jpg_640x640...jpg
the longboat in scale 1:48
Each kit is packed in a small box - so everything necessary for the boats is included
In the following I will show the Longboat
Content:
Uwek
Administrator
Administrator
Vienna, Austria
The small keel with the parts
Dry-fitted in the jig - visible are also the frames of the boat - very accurate laser cut
Here you can see the small a fragile rips / frames of the Salamandre longboat
and fitted on the keel
to be continued ....... many thanks for your interest
Uwek
Administrator
Administrator
Vienna, Austria
Hi Uwe,
Is this all in cherry?
Hallo Maarten,
yes, it is Cherry......only the rips / frames are a different timber, but I can not say which kind. It is slightly lighter than the Cherry.
But it is a good choice, due to the fact, that these parts are more stabile, than they would be in cherry. The cross section dimension of the frames is less than 2mm
Uwek
Administrator
Administrator
Vienna, Austria
Hallo Uwe, so the ribs are from wood (timber) not plywood, correct?
Now you make me anxious - I have to check it and make a clean cut through the timber and sand it carefully to see !!
I did not remove the char until now and wanted to make it after the hull structure is stabilized with some planks
BTW: The frames are only 1mm in square - so very fragile
Jimsky
Administrator
Administrator
Brooklyn, New York USA
many thanks, Uwe. The reason I asked, I have built a similar model longboat (definitely not from CAF models) and the frames where from plywood. They where super-thin, 1 mm and fragile.
Uwek
Administrator
Administrator
Vienna, Austria
Some progress to show and one photo which I forgot to post last time
The keel of the Salamandre longboat prepared
To bring planking into the necessary shape, I prepared a small form, let us see tomorrow, if the form is good enough
waiting for the planks I started the inside structure with the keelson and the bottom planking of the Longboat
BTW: frame 17 was broken on one side by heavy seas - my fingers are too thick - it will be repaired later
Uwek
Administrator
Administrator
Vienna, Austria
Looks like a nice little kit, and you said it was available to buy separately?
Mine were part of the Salamandre kit.
But they are also available separate - maybe you should contact Max
or check ebay or other portals
search with "salamandre + longboat" or "salamandre + cutter"
on ebay they cost 25 US$
Uwek
Administrator
Administrator
Vienna, Austria
looks like you are of the good start, Uwe. What kind of glue did you use to glue frames and for future use with planks?
I am a typical wood-glue modeler - and try as much as possible to use this type of glue - In germany and austria the standard glue is from company Ponal
Dry in 5 minutes, on waterbasis, so you can correct if necessary with some water and the joint is unglued
Uwek
Administrator
Administrator
Vienna, Austria
Some small progress today, could work for one hour.....
Good to have these small plastic clamps - not very strong, exactly what I needed for this thin elements
The first plank is installed
The planks for one side of the longboat
Uwek
Administrator
Administrator
Vienna, Austria
In order to install the next planks it is necessary to remove the skeleton from the jig
Yesterday I installed two planks on one side, but I am not happy with the result - maybe I have to remove them ..... to be continued ....
