Tutorial Making the gratings using Proxxon MF70
Gratings consist of longitudinal and transverse rails, reinforced in the frame. They were used on sailing ships for ventilation and lighting of the lower decks and could be in the form of removable hatch covers or fragments of the deck flooring. Also, by the type of gratings, platforms of mars, latrines, transitional bridges, and fish boats were made, so the modeler often has to deal with the manufacture of gratings for his models.
Greetings folks. Just as other features of models were simplified, so was the manufacturer of gratings. There are more than several methods of making your gratings for the model. Until well into the eighteenth century, with very few exceptions, the gratings were simulated by piercing squared holes in solid wood. The methods chosen by the modeler depend on many factors. I would say the common are the scale and equipment you own. In many years of my modeling life, I have adapted a method using a table saw and achieved very good results. However, I always wanted to try other methods to find out the benefits there. Since I recently modify my Proxxon MF70 a decision was made to try out the method of utilizing the mill. BTW, this method is not new and don't develop by me. SOS has several posts, by many of our members, describing this method in great detail. I encourage you to check them out.
Using the table saw is a great method of simulating gratings for larger-scale models. Making grating for smaller scales requires slot-saw smaller thicknesses which is hard to find. Today, I will make two sample gratings, they are not specific to any of my models or scales. The first one will be 0.90mm x 0.90mm cell, another one 1.50mm x 1.50mm cell. I used some of my scrap wood suitable for this purpose and strips stock I milled for treenails a way back. To mill the grooves I have used 0.9mm and 1.5mm endmills purchased on AliExpress, by company BB (highly recommend this brand and their endmills)
View attachment 302591 View attachment 302592
The first step is to even the surface. Here comes in handy my newest ER11 system. I use a 7.0mm endmill, Yea... fewer moves. Once the surface is even, I use a 0.9mm endmill to cut the 'Y' axis groves. Make a note, that those groves should be as twice deep as the 'X-axis groves. This will ensure the 'hollow' appearance of the cell.
The 'Y-axis groves were milled first, using 0.9mm and 1.5mm for each grating blank. I use the full deep required and a single path for each grove.
View attachment 302594View attachment 302595
The X-axis groves next. Don't plunge the mill to the entire deep of the required grove, you are risky to nock the next cell out. I suggest using two or three passes (per grove) gradually moving the Z-axis until you reached the desired depth.
View attachment 302596 View attachment 302597
I just realize that didn't take photos of the process of gluing the X-axis planks. This shouldn't be too difficult and requires just a drop of PVA glue (in each cell) and firmly pressing down the planks. Once dried, you have similar to this.
View attachment 302598View attachment 302599
Using the large size mill, I made the surface even.
Bolts imitating by drilling holes using 0.2mm. I think, it is a bit oversized but I don't have a 0.1mm drill bit ;)
View attachment 302600 View attachment 302601
One coat of Tung oil finished both examples. Just for the sake of relative size, I use the figure of a 1:72 scale. The first images are gratings 1.5mm x 1.5mm cell
View attachment 302605 View attachment 302606
Here are the images of the grating sample with cell 0.9mm x 0.9mm
View attachment 302607 View attachment 302608
I am really pleased with both examples and will definitely use the mill method in my future builds. How about you? Do you like it?
1. The technique described herein is very good. An article describing a very similar technique was published in the NRJ about six or seven years ago. This NRJ article used a Byrnes table saw instead of a router. Other than that, the grating parts produced are almost identical.
2. There is one very important detail not covered in this article that was previously covered in detail. Specifically, the size of the square openings in the lattice structure. The as-built size of the openings was determined by the size of a sailor's heel of his foot.The openings in this article are way too big. It would appear that a man could pass his entire leg through the square opening.
The sailors, almost all of them, wore no shoes. If the square holes were too large, the man's foot (most likely his heel) went through the hole and he broke his ankle when he walked on one. This heel-hole size was not an insignificant matter. In point of actual fact, it was a real matter of life and death. The max hole side dimension was about 2 -1/2 to 2 - 1/4 inches; very few heels were larger than this.. Even this size was dangerous to some of the smaller men. The size as built was usually between 2 - 1/4 inches and 2 x 2 inches; or even smaller in the 1400s to 1600s. At 1/48, this 2 1/2 inch size is very convenient because it is 1/6 inch; lots of slitting saw blades are ground to this size. However, the dimension of 1/16 inch per side just looks too big (in addition to being actually too big). On the other hand, if the squares holes were too small, they would severely diminish the airflow to the lower decks; which was a problem as this airflow feature was the reason for having the gratings to begin with.
3. If you reduce the side dimension, this grating technique has great promise. However ( seems like their is always a "however"),
there are other pertinent construction details that produce superior gratings that are not covered above that are covered in the NRJ article. I will leave these details to the assembled readers.
I love tools and machines , laths , milling machines it’s a man thing , makes me want to buy one ian
Hello @Jimsky,
I know this is an older post but I was wondering if you recall what the thickness of the stock material was? Visually it looks like about 1 cm. Is that correct?
Hello @Jimsky,
I think so, Jack. But, it doesn't play a major role, as long as there is enough material to hold it in the wise. Alternatively, you can mount the material using double-sticky tape, and use thin would stock. Some modelers prefer the 'true' holes in gratings, while others shoe the 'blind' holes. The choice is yours!
I prefer your approach. The gratings looks a lot more solid. I have a tonne of those thin gratings(one of my bad purchasing choices...) and they are hard to work with. They break easily and sometimes the holes do not lign up.
Love it Jim. This is what I'm trying to produce with my Dremel etc etc. Now I will go back to my drill press vice mounted on the X-Y table rather than clamping the timber on a board.
Excellent timing for your post. I'll be making more over the nest few days so I will post the results on my Medea log.
I will be interested to see how you go, Mate. I don't know if the Dremel will be sturdy enough to create but let's see the proof from your attempt
I think you will need extremely sharp tools to make the cuts. I guess I have a negative attitude as I forgot you are a retired farmer from Aussie. I do come from the same background also, but done an apprenticeship in Fitting and Machining also. I took the small Milling machine for granted, but I wish I had one here now for this job and many others!
My Milling machine was able to do two things and it also had a 6 metre bed. It could bore and also mill. It also had extreme accuracy for a machine of its day. The body used to run along rails and the table was fixed. It was nothing for it to take cuts of 16mm at a fairly good feed rate with its cutting heads. The swarf it left behind could easily spin and cook a pig on a spit. Burns was a problem and needed to be careful as the swarf sometimes would fly.
Just rebuilt an old lathe nearly 100 years old and I managed to mill a slot in a piece of steel and it turned out quite accurately. No good for this type of work LOL
What glue did you use to stick the wood pieces together and to the rule?
How easy is it to separate afterward?
In my scratch-build thinking so far I have woken up at night and thought about doing gratings in many ways without breaking the bank. I have all the tools to do the grating this way. I guess I could practice this before starting the scratch build.
I used double sides tape. But you can also use painters tape on both parts and use ca to glue the both parts together.
Ok yes a good idea with double-sided tape and CA for finished product but what glue do you use to glue the pieces together before cutting the slots on the rule? Sorry, should have made that clearer.
The strips are not glued together, only to the ruler with double sides tape to hold them in place. After when they are finished sawing the grooves I use white glue to glue the strips together.
It is discribed in this book I believe
The part of the book where this method is discribedThank you for the information. I guess the last illustration is using a hot poker to burn a round hole square.
Thanks Steven, useful bit of information but I think what you described is as good as this illustration.
Just try which method is perfect for you. And make it your own. That's what I always do, I look how others do it and try to do it my way. And sometimes handtools are the best solution.
Another take on making gratings if a small table saw is available. Note the guide rail to guarantee the spacing between cuts is always the same. Pictures and a 1000 words....
Alan, please post information related to the discussion in this thread. I will create a new thread and move your post\s there.
* Alann's post moved here
