- Jan 12, 2021
thanks, much appreciated!Good morning. This is good stuff. Cheers Grant
well, I'm reasonably satisfied. I made a few more adjustments after making these pictures: I discovered that I could more easily identify the gaps by shining a light at it. But still I find it very difficult to make a snug fit, and keep the ship level in all directions.Are you liking the way the base fits?
C'est très bleu.Juste un petit aperçu d'où j'en suis maintenant avec le Royal Louis
Hi, indeed this is turning into quite the experiment. My core takeaway from this process is that if I ever do such a "finishing somebody else's work " project again I'm going to do it up to my own quality standards from the start. I did a lot of backtracking on previous decisions, and feel like I'm ending up with a less then satisfactory result. I looked at a photo from the start of the project, and couldn't help feeling like she was prettier without all my effortsC'est très bleu.
Sur le mien, j'ai pas de lanterne arrière.
Je vois que tu as fait le choix de le faire sans le gréement.
indeed, they are the wrong way around, I hadn't noticed . Well spottedJe viens de voir un détail sur ton bateau au niveau des bouteilles, les fenêtres du bas sont montées à l'envers, le petit carreau est monté vers l'avant normalement et le long vers l'arrière , tu peux le voir sur tes plans.
I just saw a detail on your boat at the level of the bottles, the bottom windows are mounted upside down, the small pane is mounted forward normally and the long one aft, you can see it on your plans .
That ship's bottom would most likely have had some mixture of resins toxic to teredo worms mixed with tallow. (Beef fat mixed with kerosene, turpentine, or the like.) this would give the bottom a buttery or beige off white color. If you want to go the route of paint, use a flat or very satin acrylic, possibly over a coat of smoothly sanded gesso, (preferable to gray sanding sealer or prep, which would tend to show through the tallow paint color) as the tallow coating would obscure any treenails. This would subtly contrast with the natural wood finish above the water line and give the overall look of the ship a pleasing aesthetic and historic believability.
Thanks Pete, I'll keep that in mind. Probably for my next build![]()
10:08And here is episode 5:
J'ai regardé sur les plans du RL et cette pièce n'y est pas.10:08
You can put part of masts to make some details on deck.
(Last picture)
L'ORIENT scala 1/48 [COMPLETED BUILD]
Ciao, nel video qui sotto potrete vedere un piccolo riassunto dell'ultimo mio lavoro in arsenale, l'Oriente vascello francese di prima classe da 118 cannoni, monografia di G. Delacroix. Un lavoro quotidiano che dura da più di 5 anni completamente autocostruito. Spero vi piaccia. Hello, in the...shipsofscale.com
10:46
Under bowsprit there're always two elements(knighthead) you can see them on 4th picture counting from top
If you're already re-do things, and want to focus on hull mabye try to add those elements
Salut Martin, toujours au boulot.Préparez le canon maintenant :
