Now, first make the rudder and the tiller.
Preparations. The 2 pieces have been sawn and milled.
Glue together.
Compared to a figure, the rudder is quite large.
The rudder and tiller are largely finished.
Recesses for the hinges have been milled.
So I don't use brass for the hinges. During the build of the Corel yacht, I realized once again that this doesn't suit me.
So, make polystyrene pieces and paint them.
The hinges are not neatly spaced evenly.
They are wider at the pivot point than at the rear of the rudder.
And goaround the rudder (unusual, but seen here and there)
These polystyrene hinges provide no rigidity, so the rudder is attached to the hull with copper wire.
Drilling holes in the rudder.
And in the hull
Rudder hinges have been installed and painted .
And just tap it into place with the hammer.
Now attach the hinge pieces to the hull.
Continued working on the hinge parts on the hull. These were painted black first before gluing them in place. This makes things easier, because holding the large hull at the correct painting angle and painting it is difficult..
Next, the "bolts" are glued on. The "bolts" are cut from 1mm round plastic strip.
And then there was a rudder.
