Happy Birthday, TKAM many more years to come!
Happy Birthday, TKAM many more years to come!![]()
Looks great! Just starting this kit, not sure of the type of glue to use. Any recommendations?
How did you cut these bulkheads out, TKAM? Are they pre-cut with laser and you just have to slice through with a blade?Cutting out the middle bulkheads. It was neccessary for these to stay in place while fairing the hull and planking. Now that that's all behind us it's time to cut out the middle of each bulkhead, sand down the laser char, and fair the inside of the bulkheads.
Have you tried Dymo label tape?After conditioning the wood I sanded again with 230 grit then stained with Minwax golden oak. I'll do the simulated tree nails then a second coat of stain.
I have a problem. I marked out the waterline and for the life of me I can't get masking tape to stick so I can get a nice crisp line for the white paint below the waterline. I've tried two different types and nothing will stick. Anybody have an idea on what I can use?
Thanks TKAMIf you look at some of my previously posted pics, take a look at what looks like a printed line on the face of each bulkhead. This is actually a laser cut. The bulkheads are solid at the top and bottom and in the middle it's already pre cut. Eventually you'll saw off that top part of each bulkhead and then just break off the bottom part.
All the bulkheads and stern transom installed. I faired the bulkheads and found two to be about 1/16" too low. No amount of sanding will bring these bulkheads in line with the others. These bulkheads are exactly on line with the laser cut bearding line so I can only assume it's a flaw in these two bulkheads themselves.
No problem, I glued down strips on the bottom of these two bulkheads (#2 and #3) and can sand them down so they are on the same level as the bordering bulkheads. It's just the bottoms, up near the wales it's nice and flush.
View attachment 138400View attachment 138401View attachment 138402View attachment 138403
When the plans ask you "Fair the hull" . Not quiet sure how do you do this?
Thank you so much for the informationWhat that means Sparky is this: Pretend your hull plank has the consistency of cardboard. It lays down on each bulkhead easily. Along the middle of the boat it's nice and flush with the bulkhead and you have lots of area for the glue to do its job. But up there by the bow that cardboard plank only catches the very corner of the bulkhead, not only is there not enough area touching the bulkhead edge to glue but looking at the hull planking from the inside of the hull there are these horrific gaps between bulkhead and plank.
The goal is to "fair" each bulkhead so that when you lay down the plank it lays down flush on the bulkhead, there is lots of bulkhead edge to take glue and the curve of the hull towards the bow, and stern, is graceful with no big bumps or hollows. You'll be sanding the front edge of forward bulkheads and the back edge of aft bulkheads.
You get your planks nice and pliable like cardboard by any means you like. Some folks like to soak in hot water, perhaps with some ammonia in the water. Some folks like electric plank benders, some have plank bending pliers.
Makes sense?
