Montanes by OcCre Build Log
Coming off my first and very educational build of the HMS Beagle, I now begin my 2nd journey with another OcCre model, the HMS Montanes. A full description of the Montanes can be found here.
I know many like to see the unboxing, but unfortunately, I did not take photos of the unboxing, but it was as expected. Both of my OcCre models have been well boxed, complete and well organized. I find the instructions, photos and inventory lists to be well documented.
Before starting, I wanted to take a few minutes and reflect on my first build and remind myself of the things I would take forward to this new build:
1) Patience. Now that I have checked the "Build Complete" box for the first time, I now no longer have that hanging over my head and I believe I can be more patient.
2) Only work when I am in the mood. Some days you just don't do your best work....so, take a break from the project.
3) Use less glue. I over glued everything and spent way too much time cleaning up glue over run.
4) Test fit more often. Again, take the time to test fit things before jumping in.
5) Read ahead. Look at plans down the road to make sure you know how the part you are working on will interact with other parts, etc.
6) Think of each step as a project in itself. Too easy to try and breeze through a step when you know there are hundreds more afterwards. Best example for me was the building of the 4 lifeboats for the Beagle. They were rushed and poorly done and I will redo one day. I wished I have viewed them as separate projects and taken the care to do them right. Each table, cannon, window, etc should be thought of the same.....
OK, enough talk, I will post be pics of my skeleton assembly next.
Great advice particularly for newbie builders.
yes El Montaiñes was a 74 Gonner from Spain and was active in the Trafajger Batte. I build it In 1980 th.
and since then given help and advice to 4 other builders. The instruction is not the best, as well as part of the planks /the brown one) as well. instruction again (a mix of British components, where it should be Oriental -Spain, France. Guns are riggen the UK way, as well the mast caps -mainly the lower part of the mast. If needed help etc just shoudt- el capi
Ánimo es un buen kit y te proporcionará unos buenos ratos de entretenimiento y algún que otro dolor de cabeza.
Ánimo is a good kit and will provide you with some good entertainment and the occasional headache.
HOLA desde Mijas Malaga. Yo fue en su dia unos de los primeros dev tener el honor de este Kit en 1984 o 85
-Vivia aquil tiempo en Madrid y era un buen cliente de Model Reyma, quu en su ves era amigos de OcCre, cuando los primeros kits fue al mercadoempese con 16 años- en un par de meses 80 -
Small update, it's been tough to get time in the project this week but I have marched forward as best I could. The planking of the lower deck is complete. I went without tree nails at this scale and used 3 x 60mm boards (darken edges with pencil) which I believe give the deck plenty of character without being too busy.
I went with a satin finish, clear polyurethane - 5 coats.
Added the support beams for the 2nd deck
Finally built the support for officer's cabin and will now begin installing and planking the 2nd deck.
While doing some searching, I found an atrticle stating that the Montanes had a copper plated hull. This is news to me and wanted to ask the forum if anyone could confirm. I also found an article that listed it's service history with the last entry being on 12/3/1822 when the hull was recovered and sold at public auction. Would this not be further evidence that the hull was copper plated? Here is the service log
Copper sheating was used in general for all wooden hull ships at the end of the 18th century
If the Montanes was first time coppered in June 1805 or re-sheated, I do not know.
But at Trafalgar she was copper sheated
Ich werde meine San Ildefonso auch mit Kupferplatten versehen! Sie wurde 1805 bei der Schlacht von Trafalgar von den Briten aufgebracht.
I'm going to add copper plates to my San Ildefonso too! She was captured by the British at the Battle of Trafalgar in 1805.
Thanks for the input guys...for now I will continue building and I will try to plank the hull as perfectly as I can with the thought being I may not copper sheat it. If my planking is not up to par and I have some trouble, I can always pivot to the copper sheating. Let's see how the hull planking turns out.
OK, my first steps of getting organized, laying out parts, numbering parts, etc went smoothly without a hitch. OcCre's documentation regarding parts and inventory are excellent in my opinion.
After numbering, I assembled the skeleton and put down the lower deck. Over the next couple of days, I began planking the deck.
View attachment 443312View attachment 443311View attachment 443313View attachment 443314View attachment 443315View attachment 443316View attachment 443317
Impressive! Great start!
Bill
Looking really good !
I'm also planning to put copper plates on the hull.
I didn't saw other builds to use copper plates in the Montañés.
So i'm planning to order 10 packs of AMATI 1/72 plates hopefully it will be enough for the all hull.
Also , if you will want to change the guns , I'm now waiting for proposal to manufacture more accurate guns for the ship. so probably next week i'll have more info to share.
I am also contemplating putting copper on my hull. I've decided to wait until after I plank the hull to make the decision.
Lovely work, the use of a pencil to darken the edges of the planking was very effective. I have been thinking how to simulate caulking on my HMS Victory, seeing the very good result of your efforts has thinking I should give it a try. Again top effort, I doffs my cap.
Especially enjoyed your very first post I think your second point is very valid. Many a time I pressed on only to spend a few days undoing an evenings work.
A small update today. Actually took more than a week of 2-3 hour days but I am very happy with the results. I have completed the 2nd or main deck. I used the same boards and pattern as the lower deck. It also required a lot of time cutting out holes and notches as well as a lot of sanding and I think 5 coats of satin finish polyurethane. I am not a big fan of high gloss on a model and prefer a very soft finish, I like the wood to look "wet" but not shiny. Also started building out the support beams, etc. in the mid section.
