At the sides of each gun port, short strips of linden wood are glued to the inside surface of the planks above and below the line of ports.
The lower gun deck was planked with short lengths of linden wood and more filler was added to a low spot on the bow. The hull on the lower section of the stern appears bumpy but that's only the effect of the thin filler letting the bumpy wood surface show through. It's actually glass smooth.
Beginning planking the upper gun deck.
Holes are cut and filed square for the gun ports on the counter of the stern.
Another forgotten step. There is no deck for the lower gun deck stern chasers to rest on! Time to get clever. Two small sections of deck were created from plywood, and sized by gluing a stick to them, lowering them into the stern from the top and trimming them as required until they fit with a slight interference fit. Glue was applied to the edges and the deck plates were maneuvered using the sticks until they were at the correct level and height.
There! The deck pieces were glued below the deck sections holding the last guns of the lower gun deck. After breaking off that stick for the deck piece on the starboard side, the stern chaser guns can be placed for a test fit. Crisis averted!
The position of the gun barrel relative to the port looks okay.
