Great work so far Johan! If I could make a suggestion, I would make the windshield out of three pieces of thin clear plastic (top, front and bottom), then join them to thin strips of wood that make the frame. I hope I explained that clearly.
Then you can paint the frame pieces.
I know the frame is curved, however I have made curved wing tip frames using a jig (made of wood) that you pin thin pieces of laminate to, that are pre soaked in water. You can make 2 or 3 pieces thick by adding one at a time and gluing to the previous one. Once dry you have a solid piece that is preformed to the curve.
Just food for thought, and may be more applicable to the larger scale model.
