Thank you Uwek, I appreciate the references and opinion! It seems I got it right the first time!take a look at the cathead of the Cutty Sark - with a cat on black background
and some lions
and some lions
It's proven again: Size does Matters! Very nice carving, Dean. With a nice contrast on the black.Finished the cats head on this side…installed the pulleys and painted it, then carved a tiny Lions head for the end. It’s about 5mm in size!
It is just sitting on the deck, not in the correct place against the rail because the paint is still drying!
View attachment 362802View attachment 362803View attachment 362804
Wondering if I should paint the end face gold too, or just leave the Lion gold? Opinions?
Thank you sir!Dean - awesome little carving indeed!!
Thank you Peter! Talk about micro size!It's proven again: Size does Matters! Very nice carving, Dean. With a nice contrast on the black.
Thanks! Good to see you Mark! I’m back to work on the NL again! The Lion needs to go on soon!Hi Dean, nice to have you on board again and watching you do what you do so well. Those handmade scrolls are remarkable![]()
I can hear the roar in the distance already...Thanks! Good to see you Mark! I’m back to work on the NL again! The Lion needs to go on soon!![]()
Dear Dean,Todays progress was adding waterway boards…
First to the mid deck cannon area…unfortunately had to be 10 individual pieces between frames.
Then I stained and clear coated to better match the deck…
Next will be the cross walk…which has to be planked…but eyes for the cannons need to be drilled and just pushed into place for now.
Also waterway board at the bow deck…
This one was already done to complete this side of the ship…
The other side, feeling neglected…
Current progress on this side…
There is a support under the cat head that will be curved and tapered to join the bow rails. But that will be later. For now I left the wales too long to be trimmed later, at that point in the build.
I am almost done with this side. Just have to do cannon eyes, crosswalk and finish wale nails!
Thank you Shota!Dear Dean,
very nicet work, Those handmade scrolls are wonderful![]()
Either you're a Photoshop expert or your build is just immaculate, I think it's the latter...Todays progress was adding waterway boards…
Next will be the catwalk…which has to be planked…but eyes for the cannons need to be drilled and just pushed into place for now.
Thank you Johan! Cell phone pics...definitely not immaculate, but I give it a passing grade!Either you're a Photoshop expert or your build is just immaculate, I think it's the latter...
As far as I'm concerned, there's no need for you to improve: you'll only put us/me more to shame...Thank you Johan! Cell phone pics...definitely not immaculate, but I give it a passing grade!
I hope to improve on some areas on the other side! Once that is done I can do a little more on the decks, like trim boards at the ends and the gratings. Then its time to get the Lion on the ship and do the rails at the bow. Those will be challenging!
Dean, hi. The main thing is that this groundhog should be similar to the previous one, like two drops of water
Good morning Johan- photoshop can’t help perfection…Either you're a Photoshop expert or your build is just immaculate, I think it's the latter...
wonderful Dean
….ahh I was wondering why the Lion was so quite. Will be good to see him again.Thank you Johan! Cell phone pics...definitely not immaculate, but I give it a passing grade!
I hope to improve on some areas on the other side! Once that is done I can do a little more on the decks, like trim boards at the ends and the gratings. Then it’s time to get the Lion on the ship and do the rails at the bow. Those will be challenging!
Thank you Grant!Good morning Johan- photoshop can’t help perfection…
wonderful Dean
