Hi
@Modelship Dockyard
There are some errors in my instructions for Hayling Hoy Victor.
I don't know if you've corrected them yet, but...
Bowsprit is called as a top gallant mast, next, here i received a ○7mm diameter stick, whereas instructions say it should be at least 10mm to achieve a 9.2mm hexagonal-octagonal shape.
Another error is marking of the main mast stay. The instructions say it's 8.5x8.5, but in reality, it's 6.5x6.5.
Another problem is on mounting the mast to main step. Step dimensions hole are 5x5, but template it marked as 4x4. If someone doesn't check these two elements before cutting, they're bound to have problems.
Did you fix this in a new version of model?
Mine is over a 2 year old.
