Purchased shortly ago / sthg new in your workshop -> present it here
@Stuart Little, my problem is that the saw blades that came with the saw break/break easily, so I will try metal blades of the type that I use on my Prooxon FET saw, changing the saw blade itself is not a problem, Thanks for your attention, greetings Knut-
Knut, they maybe too big. The ones I use are 50 mm dia. on ebay, but one side of the mounting spigot has to be reduced to 9.5 mm diameter. If only Proxxon had made the KG & FET to use the same blades. I never thought to try the FET blades as I assumed they would not fit, & I did have the 50 mm ones.
Stuart
Hello Bill I will use this planer for working on the floorboards inside and outside.
Don I've added a link to the company, but I don't know if this company exists in the States.
Minor additions compared with some impressive items posted in this forum. The small, cordless, rechargeable rotary tool is the third that I have bought. The older two work fine but I get bored by repated changes of collet size. I have tried small chucks but they are never sufficiently balanced in such a small tool. The new one will be fitted to receive dremel type tools; the older two will hold small drill bits. Currently one holds a fine bit to provide starter holes for pins; the other drills holes to receive eye bolts. The second item is a pair of parallel jow pliers that grip extremely well. One jaw has a lengthwise groove (intended, I think, for holding wire) ; it holds pins extremely firmly.
I just received this sander a couple of days ago, very strongly made, it runs nice and smooth,
upright position,
side view, I will probably make a cover for the motor to keep the dust out,
and one from the back,
in the lay down position,
comes with the seven speed control and the mains lead with an Australian plug,
also comes with 10 extra belts and a set of hex keys,
thanks for looking in,
best regards John,
I have bought a couple of these mini drills, they are fantastic for small light work and I also bought five of the self closing chucks, three are for these mini drills and the other two are my cordless Dremel, I am surprised by what John said in his post above as I have never had any problems withe mini chucks, I might just be lucky and have better balanced drills or chucks, it only cost $15 AUD including shipping for all five chucks,
These chucks are beautiful to hold sit nicely in my hand, I paid $30 AUD for both the drills including shipping,
two on the left are for my dremel and the other three are for the mini drills,
They also fit on the generic type of drill,
and a close up,​
They also fit on the genetic type of drill,
and a close up,​
Where did you find the belt sander, Neptune?
Hello everyone I bought this 6 inch shop fox jointer, it's the older version so I got it on sale,actually the old version is better in my opinion with the solid steel fence the new version has a aluminum fence, I got this so I can square up rough cut boards for proper resawing,it won't be used much,but it's there if I need it, I made a adjustable table for it so it can go under my bench, I used a motorcycle sissor jack to raise it up or down with the drill, works fantastic!!!
Hi, John, I've found it, but not on ebay UK. I found it on Aliexpress (NL), for £45,97 inc.. The horizontal position is what attracted me..
Best regards Stuart
Glad you found one Stuart, but I cannot believe the price, mine was $46 AUD including shipping, that's half the price of the one quoted,
Best regards John,
