Rattlesnake by MS
Finally got off my lazy quarantine butt and got some more work done. Fore mast top sail. As before, I glued a length of wire into the seams along the sides and bottom of the sail. I painted the wire the same color as the sail and it's effectively invisible.
Sail now secured to the yard. Next is to fashion and secure the lanyard to the yard along with one end of the parrel leash, then I can mount the yard to the mast.
I have no ideas as I am working in a different port. :) Rich
I've asked ME to send replacement parts on multiple occasions, I even told the truth and said I'm bashing the kit somewhat and wanted additional parts to do so-and-so....I've never had any objections nor requests that I pay for the additional parts. They are really good that way.
Just scanned through the latter pages of your log and am impressed by the very neat rigging that you produced. The model looks like it will be one that is proudly presented. Well done. Rich (PT-2)
Thank you for the kind word Rich. I burned out for awhile but now I'm back to it.
Top sail yard for the fore mast mounted. As before, I drilled a hole for 25 gauge wire in the back side of the yard and a corresponding hole in the mast. A dab of gel-type CA glue to hold the yard in place while rigging the parrels for the truss.
In the second pic you can see the brace pendants hanging down, rigging of those to come. In the first pic you can see the yardarm lanyard poking through the mast, to be rigged.
Ironic that the last little bits, not "bitts", bits, of work is proceeding so so slowly. I didn't hit a wall, rather my company is back up and running and the V-shaped recovery is very real indeed. Tons of work, not a lot of time for model building.
After the mounted top sail sat for a month or so I was able to rig up the lines for sheets/clew/reef. The sheet lines are belayed through the lower sister block located on the lower course yard then through the block near the mast on the lower yard, then through the sheave on the bitts and secured to the cleat at the front of the bitts.
The clew line runs as you'd expect and belayed down to the pin rail at the aft end of the forecastle.
The reef line starts at a block located on the bowsprit and runs through the reef tackle block, back through the block on the bowsprit, then belayed to the forward pin rail.
View attachment 250010View attachment 250011View attachment 250012View attachment 250013View attachment 250014
looks beautiful and accurate
That is a lot of rigging to set in those gale force winds filling the sails!!!:oops: Well done. Rich (PT-2)
Yes indeed! The Captain has his blood up. He's most definitely pushing it, bending just about every spar on his ship. But he sees the prize and come hell or high water he is going to catch up and take that prize! Just another knot or two and he'll catch that British merchantman before sundown and add the contents of her hold to HIS hold. Topgallants are furled, so far, but I foresee the foremast topgallant in the process of being unfurled as the final touch to the rigging on Rattlesnake. Stay tuned....
The blocks look good and in scale. Kit or aftermarket?
looking for rigging blocks and have not visited Dry-Dock Models... Seriously? You have not heard about the best blocks you can possibly own? No worry, the help is on the way....below is the link, my friend.
Foremast top gallant sail rigged up, upper staysail rigging installed. That completes the rigging on Rattlesnake with the exception of the signal halyards. Working on the trucks for atop the masts, then I can install the flags. All that's left after that are the anchors.
dfgdfd.jpgdsfgddwa.jpgdzfsdgf.jpghnfdfd.jpgsadffdgf.jpgxfgdfgf.jpgxvvxvx.jpgzdcxbfvx.jpg
View attachment 255174View attachment 255175View attachment 255176View attachment 255177View attachment 255178View attachment 255179View attachment 255180View attachment 255181
I like your cleats. Did they come with the kit?
