"Now I am working on the Revell USS Constitution and the gun port are again giving me problems. Every time I start working the main deck I break off the gun port doors or the canons."When I joined this group I had started working on the USS Constitution made of wood. It was my first attempt at a wooded model. It was an old kit with badly hand cut parts. Everything went great until I got to the metal gun ports. Nothing lined up. I sanded the gun flush with the first layer of planking. It took me 4 month.
It seem like the super glues, Tamiya, and
Testors is having a tough time adhering to the plastic used in these old kits.
Has anyone else experienced this problem? If so we're you able to find a solution?0
You and me both!
"Testors is having a tough time adhering to the plastic used in these old kits.
Has anyone else experienced this problem?"
I built the Revell USS Constitution 42 years ago. The Testor's glue I used then may be different, using toluene as the solvent, and it seemed to stick to the sail plastic. I used a pin to punch holes near the edge of the sail, being careful not to rip a slot out of the edge, and tied lines to the clews for blocks and the head of the sail for attaching it to the yard. The sails were delicate. at the edges and could get torn free of the rigging if you're not careful. You may want to heat a pin with a torch and use the hot pin to pierce the holes. The hole will then be round, and not a straight tear in the plastic. Now that I learned Ohla's technique in cloth sails, I would never use plastic sails even again, and go with cloth since they are a bit more robust. It depends on what you are comfortable with.
