Second ever build Havmagen 683 from Billing Boats [COMPLETED BUILD]
Hi I appreciate the advice , but struggling to understand ? Do you have any photographs to illustrate your method ?
Rich
hope that this can help you a little- download the pñanking technique for beginners in a PDF format. this was my bible. I finally found the Book downloaded. click on the title or blue space and its open.
  • 220-plankingprojectbeginners.pdf
Many thanks will study this at length !
Finally finished planking the hull , may not be text book but quite pleased as only my second model.
Need to shape the stern next and lots of sanding!
It is not that bad. There are some small mistakes, which disappear with a good sanding. mine for about 55 years ago, was not that good, but on the other hand,- no information, tools poor, and no internet to help you. at that time I mostly lived in the port of Hirtshals -4Th biggest fishing port in Denmark. here I learned with 14-15 years old. when building problems I went down the Boat building unit, where I learned the steam process to bend the planks and some other things. The main difference in this type of boat -hull nearly the same -was the wheelhouse and mainly the fishing tools, made to the different fish catch.l again I had it live in the port. I thing that at that time I build about 5 units. will send some images , when In find them.
You made a good job with the planking - you will see, that after sanding and some wood treatment - it will be a really good hull planking Thumbsup
First test coat of paint a little more filler and sanding required , although conscious it's a fishing boat and needs to be rustic.
