Looking good. Shoild you turn her over and start planking? from the keel
I’ve been going through blades very quickly yeah, working with the planks/ balsa is a relief because the blades last a lot longer. I’m gonna try and use more of the wood to make parts from now on using the paper as blueprints. Will have some planking updates in the next couple of days.One of the most important things in working with paper is that you need an abundant supply of blades (#11), I use mine then when starting to show signs of wear, put them back in the holder as they are still fine for plastic and wood, but those sharp blades are absolutely critical for paper and card stock modeling.
Yes, almost as strong as woo, so go for it. I did the HMS Alert and was amazed at how strong the hull became.The addition of the wood has a question in my mind..
is the card stock framing and card stock keel STRONG enough for this addition?
Once glued the card is fairly sturdy but once I covered the lower hull with filler and sanded it down it was rock solid, I can glue the planks straight on very easily too. I’m surprised with how well it’s turning out. I have another card kit, the HMS enterprise which I’ll start on once I’m done with this and most likely do the whole thing other than the framing in wood.The addition of the wood has a question in my mind..
Does the US have a homegrown supply of lime and or pear wood, and a native source of balsa?
