Great progress...
Hallo @GuyMSo, on this log I am in the very early process of modifying and building the ship as close as possible to what it would have looked like in the spring of 1671 when the ship was to make its maiden voyage along with 4 others for the king's visit at the new Rochefort shipyard, which he cancelled, but the ships went out anyway....
The document below describes what would have been the history of the Soleil Royal and the other royal ships of that period. As well, I'm trying to reproduce the ship from a plastic Heller 1/100 kit ( 1/95 makes more sense) by modifying all the details of the decorations on the sides, the correction of the number of cannons and some structural compartments on the different decks; I am not an expert at this, so please remember when you comment on the work
The basis of the design on the stern and side galeries is from Tanneron's Soleil Royal, so they have been opened up and the interior of the galeries decorated; I have not used a wood kit because the decoration work would have been much too extensive and I do not have the abilities that some who are building ships on this site have. If you have questions on the why there are differences with my build versus others, I sugest you first read the documnt below ( if you can read french of course)
because it will answer a lot of your inquiries. If you do not read French, ask me your questions and I will answer them in accordance with what is written on that document, which also reflects my view of course
From the first pic, one can see major decor changes, I still need to scrape off the original decor between the upper portholes, I don't believe there was any of this type since that is a symbol that appears on ships near the end of the century; the refit version of the Soleil Royal had them, but not at that location. it will be replaced with the decors on the images at the end. There can be a lot of flexibility with the side decoration since there is nothing as far as information on the ships of the mid-century except for what seems to be a generalization of the fleur de lys design on the upper part, which was found on the Royal Louis, the Royal Duc ( Reyne) and on the Royal Dauphin. The figurehead is what I found on the net, what used to be a mairmais which I scaled down a bit and reworked the arms....It isn't finished as you can tell)) The work is still VERY rough, but I wanted to make all the modifications before finishing the surfaces...
Oups, a few tapping mistakesHiTell me; what brings you to believe the ship was blue? the aquarelles from Pierre Vary which were probably a color suggestion for the reconstructed version in 1690. The blue was the most expensive of the colors and the king had ordered in 1686 that no expensive colors were to be used on ships going forward; an exception would have been for smaller areas on the two bigger warships, the Soleil Royal and the Royal Louis, which never got the refit and was instead replaced in 1692. As for the very first version of 1671, though there is nothing written about the exact color it could have been, it is doubtful to me theywould have painted it blue.
There are no drawings of the first side galleries (bouteilles) for the first version, only for the rebuilt one; therefore I am relying on the Tanneron model. The reason being that he has seen apparently drawings from when Puget reworked the stern decors, a drawing which is supposed to be somewhere in the archives of either thePalais de chaillot where the actual naval museum is, or in the the Louvre's archives where the museum used to be in the 19th century....I'm still trying to find a clue of where they are))
If you cn ead french, I can send you a document I made about the Soleil Royal and the other royal ships; I found quite a bit of information and if you're interested in the subject, it's an informative read...
