was the money spent on the zhl to the us worth it
Hello Terry, Please contact Max (from ZHL), he helped a lot of SOS members (still do). He can answer the questions you specifically targeted.were instructions in english and easy to understand
Hi Terry short answer is Yes. Even at 1:90 scale the model is large and heavy, about 40 in. long and around 15 lbs. It was about $90 to Ohio. Shipping time was 9 days from the day I ordered. I was very pleased with the quality of the materials in the the kit. I will build another Chinese kit again and order from ZHL.was the money spent on the zhl to the us worth it
The instructions were ok, a little confusing in the order they are presented. There was no problem identifying each part and were it should be located but like other kits you need to look ahead on how you proceed. The kit went together with minimal adjustments. If you study the instructions you’ll find everything you need.were instructions in english and easy to understand
It is one of the few models from Kits, whey has nearly a 100 % perfect first planking. both from bottom-up and from upwards -just below the main deck- and downwards. PERSONALLY I not like this precut gunports. in many cases, they do not fit correctly, so gun pipes may go to the moon or down to NEPTUN, APART FROM THEY HAVE THE SAME SEIZE, BUT GUN PIBES change in seize from the lower deck and upwards if you insert a lover deck, but it is mainly seen at the quarter deck and forecastle, as the rest is mainly dummy gunsG'day Mike, just been through and caught up with your build, very nice work, she looks really big, looking forward to the rest of your build,
best regards John,
Thanks El Capi. The precut gunports were a pain to fit. They are nice in that it saves time but there is very little you can do for adjustment As you said. Thanks for visiting my build log.It is one of the few models from Kits, whey has nearly a 100 % perfect first planking. both from bottom-up and from upwards -just below the main deck- and downwards. PERSONALLY I not like this precut gunports. in many cases, they do not fit correctly, so gun pipes may go to the moon or down to NEPTUN, APART FROM THEY HAVE THE SAME SEIZE, BUT GUN PIBES change in seize from the lower deck and upwards if you insert a lover deck, but it is mainly seen at the quarter deck and forecastle, as the rest is mainly dummy guns
Thank you for the compliment Carlosys much appreciated.Hi
Fantastic work done in the boats as well as in the rest of the model.
Congratulations. A very pretty model.
Regards
Did you email him?hi mike.love your model hope you or some other member can help me out. how can i contact max at zhl.i have tried from other members to contact him but no answer from him. hope you can help me find a way to contact him. thanks your help
Thank you Terry for the compliment. I purchased my kit on EBay. Max has an eBay store, I contacted him there. He is modelshipkit on eBay. He responded back within a few days.hi mike.love your model hope you or some other member can help me out. how can i contact max at zhl.i have tried from other members to contact him but no answer from him. hope you can help me find a way to contact him. thanks your help
