Frames glued. Beams cut to correct length. Only last Stern frames is not glued because I still need to glue a transom section that supports that frame.
I am bending a hull plank. Need to bend 3 more.
For future builders, if any, 2 frames were short. Frames 3 and 4 counting from the bow to stern. If you zoom you will see I added a piece of the wood and shaped it. I thought of doing both completely new. But I do not have that wood. If I do them in cherry, then I will have to do all the frames. I decided to let it as it is.
View attachment 288335View attachment 288336View attachment 288337View attachment 288338
Cheers
Daniel
