The Frederick from the Lumberyard
Your framing is looking very good - I think you are on a very good way
Hello Uwek
Thank you for your kind reply. I work with the thought of trying to keep everything in line, symmetrical , level.
Building a model such as this is a challenge to me planning ahead , thinking how each piece I place now impacts future .
I keep many pieces of paper for notes and reminders and sometime sketches to assist me.
I enjoy the process and adding these posts to possibly help others .
Hello everyone
Today I glued the keel assembly to the full frames. I also removed the front angle supports. I will be doing more sanding and fairing inside then glue keelson .
The half frames are next. Like the full frames I’ll
Use the milled stock to make patterns to attach
Templates of half frame drawings.
Regards to you all
Rick
The process of making full and half frames from milled stock is a good step up for me. I’m enjoying this process and have learned a lot Perhaps it might help others as I have learned from others here.
In the process of setting the last frames at stern I noticed the spacing of frame 36 to 39 wouldn’t give the last frame ( 40 ) to transom relationship what it needed.
I ended up re-doing 36 thru 39. It moved the back end of f40 closer to transom.
See plan elevation drawing vs model.
My little sketch plan shows how to f40 to transom will end up .
Once frames are faired I’ll be looking at transom and stern timbers , attachment of Wales and clamp.
For now ,frame by frame they are brought into line. She is taking shape.
Thank you for for stopping by this build.
hello to everyone here
I’ve been concentrating on the stern construction. I’ve added the transom and stern timbers plus the horizontal pieces that define the stern gun ports. I also enclosed the outside space from the stern timbers to the last frame.
Everything needs sanding to prepare for Wales and planking.
I see you're using the actual Hahn method. I used it for only cutting out my frames on my Le Rochefort and wasn't happy at all. The joints weren't in the right place and the bottoms of the frames at the keel I tried to short cut and not mill the proper rabbets. It was a disaster. In the drawing the Dave made it seems the joints are in the right place. Is that correct ?
Hello Tony
First, sorry for late reply . The drawings Dave provided for this build were CAD drawn. Jig, keel, frames have come together well. Even with everything provided for me I correct my errors and re-do parts.
Having added wales I’ve removed model from jig.
Will be sanding outside and inside in preparation for clamps , planking above wales.
Here’s wishing you all a Happy New Year.
Stay well and take care.
Rick
